Replaced dead battery but is my alternator working properly?
Postby Crusader556 [OP] » August 22nd 2008, 3:28pm
The battery in my wife's 2000 AWD LT died yesterday. The battery light flashed while she was driving and after stopping and turning off the van there was not enough juice to start the engine agian.
The battery was over 3 years old so I replaced it with a new one but after starting the van I noticed that it did not look like the voltage went up after the engine was running or while we were drivng the van back home.
The voltage stays at right around 12 volts. While driving I noticed it would drop down a to about 11 or 10 volts if I turned on the A/C with the fan on high.
I don't remember what the voltage reading was when the old battery was working but it didn't look right to me. On my Jeep the voltage will go up to about 13.5 or close to 14 after starting the engine and while driving.
To me it looks like the the alternator on the Astro may not be working properly or even at all. What do you guys think?
Is there an easy way to test the alternator before I get a new one and start taking things apart?
Thanks!
Crusader556
Years of Membership: Crusader556 has been a member for 12 full yearsCrusader556 has been a member for 12 full yearsCrusader556 has been a member for 12 full yearsCrusader556 has been a member for 12 full yearsCrusader556 has been a member for 12 full yearsCrusader556 has been a member for 12 full yearsCrusader556 has been a member for 12 full yearsCrusader556 has been a member for 12 full yearsCrusader556 has been a member for 12 full yearsCrusader556 has been a member for 12 full yearsCrusader556 has been a member for 12 full yearsCrusader556 has been a member for 12 full years
Topics: 19
  • Strange clicking under dash, dead battery
    by cathairez » February 29th 2020, 10:02pm in Electrical
    March 2nd 2020, 10:01pm
  • could the stock radio be draining my battery?
    by txbanana » April 25th 2020, 12:25am in Electrical
    April 25th 2020, 11:39pm
    44
    August 12th 2020, 5:29am
Re: Replaced dead battery but is my alternator working properly?
Postby red95astro » August 22nd 2008, 3:41pm
Sound like the alternator to me. Also, just from experience, I've had alternators go out on cars intermittently. Basically, instead of just going out like a bad light bulb, one minute it worked, then it didnt. It had me so confused because I had it tested twice and it tested fine both times. Try putting a voltmeter on the battery while the engine is running. If it reads any less than 13.4 volts, your alternator may be to blame. Also, check the connections, especially the wire from the alternator to the battery. If there is any corrosion or resistance, it can affect the charging abilities of the alternator.
red95astro
Years of Membership: red95astro has been a member for 11 full yearsred95astro has been a member for 11 full yearsred95astro has been a member for 11 full yearsred95astro has been a member for 11 full yearsred95astro has been a member for 11 full yearsred95astro has been a member for 11 full yearsred95astro has been a member for 11 full yearsred95astro has been a member for 11 full yearsred95astro has been a member for 11 full yearsred95astro has been a member for 11 full yearsred95astro has been a member for 11 full years
Alias (AKA): Scotty Boy
Postby kidhauler » August 22nd 2008, 6:08pm
The best way to test the alt. is to take it out and take it to your local auto parts store any of the big stores should be able to test it usually for free. If your alt tests good then check your fuseable links that go to the starter motor. I had one rub on the frame one time and burn up so the Alt stopped charging I replaced the alt before I found the lead was bad. To this day I don't know if I chucked a perfectly good alt.
Gone to happier grounds.
kidhauler
Years of Membership: kidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full yearskidhauler has been a member for 12 full years
Postby red95astro » August 22nd 2008, 6:15pm
But like I said, you may have it tested at a local parts store and have it pass the test. Mine did show up twice as good. Athird time it tested god, but then failed instantly as the test was being performed. In a nutshell.....dont figure that the alternator is absolutely good because the test says its good. All that means is that it was performing fine at the time of the test.
red95astro
Postby Crusader556 [OP] » August 27th 2008, 2:55pm
Update:
The alternator was defintely bad. It was tested several times and it never worked.
I replaced the alternator using the info in the Alternator Replacement tacked thread and while it was a PIA at times the swap out went pretty smoothly!
Thanks for the help guys!
Crusader556
Topics: 19
It is currently August 12th 2020, 5:29am
Sailing_Faith
Comments: 17
Date: Aug 10 '20
Time: 2:17am
doogaloo
Comments: 17
Date: Aug 09 '20
Time: 8:52pm
Attached by: kittenflaps
kittenflaps
Comments: 18
Date: Aug 07 '20
Time: 12:46am
Sailing_Faith
Comments: 17
Date: Aug 06 '20
Time: 4:48pm
Attached by: bowtie262
bowtie262
Date: Aug 02 '20
Time: 8:41pm
