by qbubuu [OP] » January 3rd 2019, 1:34am
by TurnNburn » January 3rd 2019, 2:01am
by MechBob » January 3rd 2019, 2:12am
by qbubuu [OP] » January 3rd 2019, 2:47am
TurnNburn wrote:Didya give ol' google a clickaroo?
https://www.youtube.com/watch?v=-NzWgqEGfD8
https://www.youtube.com/watch?v=2qBJq9tSB_4
https://www.diyforums.net/how-many-star ... 37088.html
by qbubuu [OP] » January 3rd 2019, 2:49am
MechBob wrote:You screwed up.The big wire,with the "locating lug" is the battery wire.Depending on how long you let the battery hooked up,you may have fried several things.Without more information,I do not think we can help you.
by MechBob » January 3rd 2019, 3:00am
by Big_kid » January 3rd 2019, 3:06am
by qbubuu [OP] » January 3rd 2019, 3:09am
MechBob wrote:The wire with the piece jutting out to the side is the battery wire.The other wire,on the big lug,feeds power to the van.The much smaller wire is the activation circuit ,to engage the starter.When you removed the starter,you probably pushed the battery wire out of the way,then forgot it.You probably have burned up a fuse able link.
by qbubuu [OP] » January 3rd 2019, 3:11am
Big_kid wrote:^^ What Bob said.
by TBLBill » January 3rd 2019, 4:06am
by qbubuu [OP] » January 3rd 2019, 4:13am
TBLBill wrote:You'll only know for sure if you wire everything correctly and try it, or test the wire with a multimeter to see if you burned up a fusible link. After my frame swap I mixed up two starter wires; I didn't have sparks, but the alternator wasn't charging the battery. There's a fusible link in the thick wire that goes from the starter to the alternator that may have been burned up.
Try connecting everything properly and see what works and what doesn't. The loops on each of the wires connecting to the starter should fit in their studs pretty closely, so you should be able to easily tell which wires go to which posts.
by MechBob » January 3rd 2019, 4:32am
qbubuu wrote:MechBob wrote:The wire with the piece jutting out to the side is the battery wire.The other wire,on the big lug,feeds power to the van.The much smaller wire is the activation circuit ,to engage the starter.When you removed the starter,you probably pushed the battery wire out of the way,then forgot it.You probably have burned up a fuse able link.
Well what makes you think that? It only sparked for a moment. So the battery wire goes on top of the other wire. Does the piece jutting out have to be touching something specific or be in a specific position?
by TurnNburn » January 3rd 2019, 5:58am
by TBLBill » January 3rd 2019, 6:12am
by AstroWill » January 3rd 2019, 10:59am
by sixsix » January 3rd 2019, 1:16pm
by markmitch » January 3rd 2019, 5:38pm
by sixsix » January 3rd 2019, 5:49pm
markmitch wrote:You can go to auto parts store buy a section of the fuse able link wire add it to this: https://www.ebay.com/p/Soundbox-Connect ... 66695144to buy some ends and replace the fuse able link and wire.
What you need is a fusible link that is 5.0 square mm in cross section, rated for 50 amps, about 6 inches long, unwrapped in free air, not enclosed within a harness or convoluted tubing, and incorporated into your 6 guage charging wire as near to the battery as feasible.
In general, fusible links are sized 2 guage sizes less than the parent wire they protect... so two wire guage sizes smaller than 6 guage would be 10 guage. And 10 guage is equivalent to 5.0 mm sq.
by AstroWill » January 3rd 2019, 6:07pm
markmitch wrote:What you need is a fusible link that is 5.0 square mm in cross section, rated for 50 amps, about 6 inches long, unwrapped in free air, not enclosed within a harness or convoluted tubing, and incorporated into your 6 guage charging wire as near to the battery as feasible.
by markmitch » January 3rd 2019, 6:50pm
It is currently February 28th 2021, 1:40am
Electrical Forum |
Previous topic Next topic |
Sponsors |
