Instrument panel problems
Postby bpo [OP] » May 3rd 2019, 9:35pm
For a little while now, I've had intermittent cruise control issues: the cruise control would work, but then the "brake" red light and "ABS" yellow lights would appear and it would stop.
This was minorly annoying. However, last night, something more serious has happened: the fuel gauge & oil temperature gauges no longer work.
Additionally, I cannot see the drive selector or the odometer with the engine running (I can see both with the engine off & the ignition turned one position forward).
Any ideas? This is starting to concern me. I looked in the owner's manual and found "position 6" in the fuse underneath the steering column as maybe related? I pulled the fuse. It looked fine, but I replaced it anyway. No effect.
Any suggestions? I am a bit out of my depth here, so I appreciate even simple suggestions, especially if well-explained.
Oh, also the side power mirrors do not work. I kind of assumed it was the switch, bought a spare and have been meaning to swap it. Maybe unrelated, but maybe a clue to just general electrical issues?
Thank you! I am only a recent owner - opportunity to buy kind of fell in my lap & I jumped on it as a 2nd car, but I'm not sure how qualified to own this I am exactly. I've enjoyed owning it (other than this issue).
2004 Astro AWD
bpo
Years of Membership: bpo has been a member for 1 full year
  • CEL not working correctly, Instrument panel?
    by Themistocles » November 28th 2020, 5:40pm in Electrical
    December 4th 2020, 1:25pm
  • Instrument pinout 97 Astro
    by Delshan » December 6th 2020, 12:43pm in Electrical
    Last post by Delshan View the latest post
    December 7th 2020, 1:07pm
    87
    March 7th 2021, 6:14pm
Re: Instrument panel problems
Postby AstroWill » May 4th 2019, 1:01am
Sounds like a bad ground(s) and/or connections somewhere. I would start testing/cleaning/tightening them first. Grab the GM Techline eSI(link in my sig) as it will have all of the wiring diagrams and ground locations for you.
Images: 472
Postby bpo [OP] » May 4th 2019, 5:51pm
Turned the climate control to "off", and the instrument panel came back!
This would further point to a bad ground somewhere I believe, correct?
I will work on cleaning those first & see what I find.
bpo
It is currently March 7th 2021, 6:14pm
Date: Mar 04 '21
Time: 11:56pm
OldSchoolNoe
Date: Mar 01 '21
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Users browsing this forum: Google [Bot] and 13 guests
