Battery good, alternator new, not charging
Postby sonomaguy [OP] » June 4th 2019, 1:50am
I was driving home the other day and when I looked down and noticed the alternator was only charging the battery at about 9 V I slow down for about 10 minutes as I was behind a grader at which point I noticed it was charging at 14 V again then. As I got to my destination I noticed it was back down around 9 V and on my way home it had dropped down almost into the red. I took the battery in it and got it checked out as it was only a-year-old and they said it was still good to 800 CCA. The only other thing I thought it could be would be the alternator so I picked up a rebuilt alternator put that in and it is still charging poorly to the point where it died on me on the way home I put my spare battery in there that I had just been using in the other vehicle and it still wasn’t charging that good so doesn’t appear to be battery or alternator. Any other ideas what it could possibly be? I am really puzzled at this point I’m not sure which way to turn any thoughts would be great thanks
sonomaguy
Years of Membership: sonomaguy has been a member for 6 full yearssonomaguy has been a member for 6 full yearssonomaguy has been a member for 6 full yearssonomaguy has been a member for 6 full yearssonomaguy has been a member for 6 full yearssonomaguy has been a member for 6 full years
  • Good High End Alternator?
    July 4th 2020, 2:16am
  • New alternator and Cable install...Inline fuse size?
    by fleetline51 » July 26th 2020, 9:46pm in Electrical
    July 28th 2020, 11:16pm
    96
    August 9th 2020, 6:00am
Re: Battery good, alternator new, not charging
Postby akforceten » June 4th 2019, 3:53am
defective alternator and make sure all connections are clean
98638 100250
akforceten
Years of Membership: akforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full yearsakforceten has been a member for 10 full years
Topics: 32
Images: 128
Alias (AKA): akforceten
Extra Info: SLE 4x4 7 inch lift
Postby smokinjoe » June 4th 2019, 5:37am
Its a principal of mechanics. Replacing a component does not rule it out as defective. Could be the regulator in the alternator? Maybe if you could test the voltage as it exits the alternator.
smokinjoe
Firing on 5 Cylinders (L2)
Topics: 268
Alias (AKA): smokinjoe
Van Model Year: 2002
Extra Info: RWD
Postby Sailing_Faith » June 4th 2019, 7:26am
Check the wire ing, especially the primary charge wire, the one that bolts on.
Sailing_Faith
Topics: 56
Images: 5
Alias (AKA): s/v Faith
Extra Info: SLT 4.3l RWD G80
Postby N6KB » June 4th 2019, 12:35pm
Is the Voltage gauge on the dash board the only one you have used so far? Maybe the gauge or wiring to it is faulty and the battery and alternator are not having any problem at all. I suggest measuring the voltage with a trusted meter directly across the battery terminals and also directly at the alternator output. And check all connectors and fuses associated with the charging system.
N6KB
Years of Membership: N6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full years
Topics: 49
Images: 6
Alias (AKA): N6KB
Postby Nikko » June 4th 2019, 3:07pm
Agreed. Check the alternator output directly. Do not forget about the alternator bracket, it supports the alternator and grounds the alternator. I did the big 3 upgrade and never looked back.
Nikko
Years of Membership: Nikko has been a member for 1 full year
Images: 2
Alias (AKA): Steph
Extra Info: SLT
Postby AstroWill » June 4th 2019, 3:31pm
Definitely check the wiring going from the starter up to the alternator, it contains a fusible link.
Topics: 106
Images: 437
It is currently August 9th 2020, 6:00am
Attached by: kittenflaps
kittenflaps
Comments: 18
Date: Aug 07 '20
Time: 12:46am
Sailing_Faith
Comments: 9
Date: Aug 06 '20
Time: 4:48pm
Attached by: bowtie262
bowtie262
Date: Aug 02 '20
Time: 8:41pm
Attached by: markmitch
Comments: 40
Date: Aug 01 '20
Time: 10:43pm
Attached by: Wokka
Wokka
Date: Aug 01 '20
Time: 11:13am
