Hi,
Van is driving me nuts - pretty sure I got a bad "new" alternator from the LAPS, but want to confirm before I pull that damn shroud apart again.....
Summary: 2 weeks ago pulled into the driveway at the house after a 40 mile trip and the battery symbol illuminates on the dash - damn!
Immediately check the dash voltage gauge and sure enough, it is way down below the standard 14.
Confirmed with a Fluke meter - charge at the battery while running is less than 10 volts - dead alternator.
Off to Autozone new alternator (did not buck up for the most expensive option, expect I told them to give me el cheapo)
Fought that damn shroud off there and got the new alternator in along with a new serpentine belt - all good, seeing a 14.5 v charge at the battery - fixed!
Week later (only drive the van 1 or 2 times a week for side hustle job) - sitting at an off ramp noticed that the lights on the dash and clock were strobing - checked the dash voltage gauge and could see the needle jiggling between 14-16 volts - double damn!
Confirmed with the meter - voltage strobing between 14.5-15.7 - think anything around 16 is going to start popping fuses.
Parked the van for the night, next morning decided to check cold battery - 10.5 volts! Back to the LAPS for the cheapest-ass battery they had, replaced that - did not fix the voltage flux - triple damn!
While looking at connections, terminals, etc while the motor was running - saw the belt tensioner was really bouncing - like 1-2" in sequence with the voltage flux - ah ha! - thought I found it, ordered a AC Delco direct OEM replacement and swapped it out (note, while the belt was off again and that heinious shroud, wiggled and checked all pulleys for play or rough turning - no issues found) - fired it up, and don't you know it - quadruple damn! voltage still fluctuating.
Anyway, fairly confident the voltage regulator in the el cheapo alternater is crap - what else could it be? am I missing something - I checked all the grounds I could find, all connections are tight and clean (stripped the bolt on the neg side of the stupid side post battery and had to replace that...)
So going the pull that detestable shroud once again and take that pos alternator back up to the LAPS but think it will probably check "ok" on their equipment - it's not throwing any codes in the van - don't want to get into a thing with them about whether it is good or not, but expect if I leave it as is it will fail eventually or fry something like the ECM and we don't want that...
SC
