Hi i new one guy here and i have my van problem , now i push brake pedal and goingi on all parkind and side lights , light are zero stays , i putting parkind zone and here go to light on hite brake and turn lights go to on , what the problem is on where to searching problem i chek back light bulb and cables there is ok negative cable cheked its ok all negativ to body are cleaned aa and i have battery charge volts 13.5 volt are this ok .
I need really help im really thank all who teach me remove problem .
There is a short between the brake light circuit and the parking light circuit. I have seen this several times. It is commonly caused by the wrong bulb in a brake light socket or pinched wiring.
Thanks i watch this bulb do you have t20 socket back light , i was t10 parking light back and normal bulbs simply are running light maybe this van light built europa standards where do find original bulb sockets maybe sonething ciricut wiring or picture user manuals sonething what i take solved problem .
Now thansk for everyone so much , i solved problem , now problem ise the back light sockets i clean all sockets back and now working , only what i need work i press brake pedasl and back turn signal go on too but this is not big problem , so i lost my reserve light too but i solved this fast only 2 houers now there lost positive cabel and i connect this left side for driver go down there a green cabel what switched gearbox reserve activate now connect there and put reserve gear and this is solved easy problem who want i take picture , so i really thanks all who helping me answers , i hope i can help to here someone one day just ask .
THANKS
next project i want to make dual battery charging system with roof solar panel and controller
23.1K members
