correct wire gauge from battery to the starter
Postby misterjones [OP] » December 6th 2019, 8:52pm
I was replacing the starter on my 2000 Safari when the eyelet on the cable running to the battery broke off (the heavier gauge cable). I'm assuming this is 2 gauge wire, but is it? I'm having a bear of a time finding 2ga long enough to get from the battery to the starter locally (last one was 42"), but 4ga long enough is readily available. Can I go with 4ga or do I really need to stick with 2?
misterjones
Years of Membership: misterjones has been a member for 1 full year
  • Question about the starter
    by bradaskins » June 1st 2020, 7:43pm in Electrical
    Last post by Astrofarian View the latest post
    June 2nd 2020, 2:00pm
  • How to find live brake wire for trailer brake
    by randynavarro » May 29th 2020, 5:46pm in Electrical
    Last post by randynavarro View the latest post
    May 31st 2020, 7:18pm
    9
    40
    October 26th 2020, 1:29am
Re: correct wire gauge from battery to the starter
Postby tungtide » December 6th 2019, 10:14pm
bigger is better. Clamp/solder your own ends on and get the wire from an electrical supply.
Ken
tungtide
Topics: 23
Images: 12
Alias (AKA): tungtide
Van Model Year: 2002
Postby misterjones [OP] » December 6th 2019, 10:45pm
crimping 2ga wire without the proper tool is near impossible.
misterjones
Postby Mmusicman » December 6th 2019, 11:23pm
I always went 1/0.. but that was with battery mounted in rear
I would definitely not go smaller than 2awg.
If you shop, you can find it. Welders use it too.
They might even carry it at Home Depot.
You could order a piece online.
Trucking supply, boat supply, alternator rebuilders, etc, etc
Heck, some LAPS carry heavy gauge wire with ends already on.
Firing on 6 Cylinders (L5)
Topics: 72
Images: 49
Postby AstroWill » December 7th 2019, 6:58pm
misterjones wrote:crimping 2ga wire without the proper tool is near impossible.
The hammer crimpers can be had for about $15 so that is not really a deterrent. Or go to a local hose/cable service place and have them make the cable for you.
Topics: 106
Images: 438
Postby misterjones [OP] » December 7th 2019, 7:18pm
One additional question: The heavy gauge wire coming from the battery, does it go directly to the starter solenoid or does it terminate somewhere else and the solenoid gets power from that termination point? I ask because I'm looking at this diagram and trying to make sure I get this right.
https://www.carfusebox.com/chevrolet-as ... g-diagram/
misterjones
Postby markmitch » December 7th 2019, 8:09pm
Firing on 5 Cylinders (L6)
Topics: 608
Images: 20
Extra Info: RS V8
Postby Leeann_93 » December 7th 2019, 11:21pm
Postby misterjones [OP] » December 10th 2019, 3:40am
Ok.
So, I installed the starter completely using a 78" Duralast 4ga battery cable. The old wire is still there and the new one is running alongside the protective covering because I simply didn't really have the right equipment to do this in the first place so when I have the money to get a pair of heavy duty jack stands and a proper 6 or 12 ton floor jack so I can really get it up in the air, but all I had to work with was a small 2 ton jack that I bought years ago for my old Escort.
So far so good, the starter works well and all things electrical seem fine.
Thanks for the help.
misterjones
It is currently October 26th 2020, 1:29am
Date: Oct 24 '20
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Users browsing this forum: No registered users and 27 guests
