intermittent alternator charging
Postby doomytunes [OP] » January 5th 2020, 2:22am
Hello all!
I've been using this site a lot over the last few months as I convert a 1995 AWD Astro into a covert camper and it has been an immense help. I got a good 6000 miles in over the past 2.5 months until it all started coming apart...
As I was driving one night, my blinkers started flashing very slowly and I noticed the voltage dropping from its usual spot between 13-14 down to about 9 volts over about 5 minutes. As it got that low the engine started to backfire and die and as I was slowly rolling over the rumble strips on the side of the highway, it suddenly jumped back to normal voltage and continued driving as usual. Drove okay for a day and then started to do it again. Pulled into O'Reillys and they said the alternator and battery looked fine, but the voltage regulator was bad. I replaced the full alternator and now sometimes it charges, sometimes it doesn't. When it's working, im getting 14.5 volts registering on the gauge and at the battery, and about 11.5 when it's not. Sometimes I start it and it doesn't charge at all, sometimes it does for 20 minutes then drops down again.
The strange thing is that when it's low, I put a voltmeter on the battery terminals and get 11.5, but if I put one end on the alternator B+ and the other on a ground or on the battery neg, it shows 14.5 volts, so I don't think the new alternator is bad (but I could very well be wrong). Is this a symptom of a bad voltage regulator still, or does it sound like the fusible link between the two is bad? I have been trying to find that link and am having trouble tracking it down too...
Any help would be very appreciated! Thanks in advance!
Jack
doomytunes
Alias (AKA): Jack
  • Good High End Alternator?
    July 4th 2020, 2:16am
  • alternator questions
    by markmitch » July 6th 2020, 6:22pm in Electrical
    July 7th 2020, 11:30pm
    August 12th 2020, 4:18am
Re: intermittent alternator charging
Postby chevymaher » January 5th 2020, 3:31am
Heavy wire going from the alt. Look for a fuseable link. It is fried. Should be one between the alt and battery.
Postby N6KB » January 5th 2020, 7:26am
Regulators have been built in to the alternator since at least the late sixties. Pretty much not serviceable except for replacing the whole alternator. From your voltage measurement directly at the alternator I would say there is nothing wrong with it. There is something wrong with the wiring between the alternator and the rest of the system. A loose connection or bad fuseable link as Chevymaher said.
N6KB
Years of Membership: N6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full yearsN6KB has been a member for 7 full years
Topics: 49
Images: 6
Alias (AKA): N6KB
Postby doomytunes [OP] » January 5th 2020, 4:01pm
That's just what I was thinking too. I'll swap it out and get back to you guys. Thanks for the quick replys!
doomytunes
Alias (AKA): Jack
Postby AstroWill » January 9th 2020, 10:54pm
Check/clean/tighten your connections at the back of the alternator, down at the starter, at the battery, and where the negative attaches to the body.
Topics: 106
Images: 437
Postby doomytunes [OP] » January 16th 2020, 8:13pm
It worked! Fusible link was bad. thanks for the help everyone.
doomytunes
Alias (AKA): Jack
Postby AstroWill » January 17th 2020, 2:32am
Awesome, glad you got it fixed!
Topics: 106
Images: 437
It is currently August 12th 2020, 4:18am
Sailing_Faith
Comments: 17
Date: Aug 10 '20
Time: 2:17am
doogaloo
Comments: 17
Date: Aug 09 '20
Time: 8:52pm
Attached by: kittenflaps
kittenflaps
Comments: 18
Date: Aug 07 '20
Time: 12:46am
Sailing_Faith
Comments: 17
Date: Aug 06 '20
Time: 4:48pm
Attached by: bowtie262
bowtie262
Date: Aug 02 '20
Time: 8:41pm
