No service engine light with key in on position no start
Postby Astroslide94 [OP] » February 3rd 2020, 11:12pm
Idfk what is going on with the"love machine" but i know that ive been living out of her for over a effing week now n im tired.. After all the research n all the trouble shooting ones unexperienced mind can stand im ready to light this ***** on fire!! I've went thru a process of elimination, marking off one by one a list of potential issues n the last one is a bad ecu/emu whatever the hell its called..
Here are my symptoms:
No service engine light when key in on position..
No interior lights
No dash lights or Headlights
Crankz but no start
she's got 338,000 miles on her n a jenky *** push button start
Please note: I've went thru the fuses relays wiring etc
Please help
Astroslide94
Alias (AKA): Desireé
Extra Info: 4.3L z
  • security light (cranks, no start)
    by 1989AllPro » May 31st 2020, 4:29pm in Electrical
    June 7th 2020, 5:38pm
  • Crankshaft position sensor
    by Devonian » November 12th 2020, 3:12pm in Electrical
    Last post by Devonian View the latest post
    November 14th 2020, 7:59pm
    9
    91
    November 25th 2020, 3:06pm
Re: No service engine light with key in on position no start
Postby Old Barney » February 4th 2020, 12:38am
Ok! look behind the battery. lift it out and look at the wiring there. There is a junction of either three or four can't remember back there and called fuseable links. one could be bad OR the terminals could be corroded. Find someone with a good meter and who knows how to use it start by looking a with the meter at the top of every fuse in each fuse box there is a spot that one lead from the meter touches the metal inside the fuse. The first place to look is start at the supply (the battery) make sure the terminals are clean, go to fuse box Make sure there is juice getting to the fuse box with meter.
A test light will also help. but an inexpensive meter can be found at any auto supply or walmart type store. Wish I could help more but at this point I would have to be there with my meter. good luck I hope your staying warm hope your in the southern states and not up in the north without van running.
Old Barney
Years of Membership: Old Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full yearsOld Barney has been a member for 6 full years
Topics: 23
Images: 47
Alias (AKA): Barney
Extra Info: awd
Postby Big_kid » February 4th 2020, 4:33am
What He said. If that's not it look at the visible links coming off the starter.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
Postby AstroWill » February 6th 2020, 2:48am
Astroslide94 wrote:Please note: I've went thru the fuses relays wiring etc
I would grab a meter and start with the battery and work your way towards the fuse box. There are obviously multiple circuits that are not being powered. Of course with your push to start button that is all aftermarket so who knows what all has been done with the wiring.
Images: 443
Postby AstroWill » February 7th 2020, 6:31pm
The aftermarket push button starter stuck in my head for some reason.
I would still start at the battery, but I'm wondering if the ignition switch is going bad and that is why they added a push button for your starter. Just a thought.
Images: 443
It is currently November 25th 2020, 3:06pm
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
Date: Nov 19 '20
Time: 7:31pm
