dutch door electrical question
Postby markmitch [OP] » February 5th 2020, 9:56pm
Not sure where to put this but since it is electrical in nature I thought here would be good. I would like to know if any year Astro or Safari came with dutch doors whereas the key fob has a button to open the hatch? If so what years? I am installing dutch doors on my 89 from a 94 and would like to add a way to open from outside the van such as a key fob or a hidden button so any info would help me to figure out a way to do such a thing to my van. Thanks Mark
Firing on 4 Cylinders (L6)
Topics: 596
Images: 20
Extra Info: RS V8
Re: dutch door electrical question
Postby equitube » February 13th 2020, 9:43am
My 96 Safari has that on the keyfob. It is an Explorer conversion build but I don't think that has anything to do with it, but I don't know. It never has worked right for the back door since I've had it though
equitube
Years of Membership: equitube has been a member for 1 full year
Topics: 5
Van Model Year: 1996
Extra Info: Explorer conversion
Postby Lee in Mountain View » February 13th 2020, 4:03pm
My 2005 Safari has that function on the key fob as well.
My Tow Vehicle!
Years of Membership: Lee in Mountain View has been a member for 3 full yearsLee in Mountain View has been a member for 3 full yearsLee in Mountain View has been a member for 3 full years
Topics: 21
Postby markmitch [OP] » February 13th 2020, 4:26pm
Thanks guys I am going to use a weatherproof switch hidden on the body of my van to be able to open it from the outside I think, But I will have to figure out how to unlock it at the same time. Maybe two switches? When I get ready to do the door swap I will post how I dod it.
Topics: 596
Images: 20
Extra Info: RS V8
Postby sfeaver » February 13th 2020, 9:25pm
There should be a keyswitch on the back door that pops the top too... I'm going from memory on an old 93 I'm sure had it, my 97 definitely does.
sfeaver
Firing on 8 Cylinders (L1)
Topics: 29
Images: 20
Van Model Year: 2001
Extra Info: LT RWD 350ci V8
Postby markmitch [OP] » February 13th 2020, 10:44pm
I got the doors all off but the two lower doors are still together in the middle , the key will not open them and there an electric door lock switch holding them together I need the wiring diagram for the rear electric door lock set up so I know where to put power to open them-Anyone?
Topics: 596
Images: 20
Extra Info: RS V8
Postby MechBob » February 14th 2020, 6:25am
Sorry,Mark, been busy plowing snow. With doors off, cannot you remove cover from right door and unlatch? Anyway, if it helps I believe the white colors for the lower lock solenoid are purple and white, at least in a 96.
MechBob
Blue Status (L2)
Blue Status (L2)
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Rod's TrucksRod's Trucks is online! » February 14th 2020, 6:53am
I am not sure I am reading your post correctly: But on my '98, the two lower doors are purely mechanical latches.
The hatch is a solenoid operated linkage, operated by the switch in the key lock button.
On mine, the electrical switch(in the key lock button) began to get flaky, and finally quit completely.
I removed the hatch inner trim pieces and was able to get at the linkage, and was able to get the hatch open.
The key lock and push-button switch can be disassembled ( carefully) and the contacts can be cleaned. In my case, I found an assembly in a P' n P'. Removing the key lock/push button assembly requires the removal of the rear window wiper assembly ( if installed). I replaced the original switch assembly.
Since I do a significant amount of camping and Amateur radio stuff from the back of my van, I wanted an easy way to open the rear hatch from the inside. I simply wired around the contacts and installed a small push button switch on the lower edge of the window trim panel ( wired in (parallel with the contacts on the external switch) .
If I am inside and want to pop the hatch, I can just push the button and the hatch releases. One of the switch wires that I need to tap into was purple. The other might have been orange.
Rod J
Topics: 19
Images: 47
Alias (AKA): Rod and/or WE7X
Postby AstroWill » February 14th 2020, 4:44pm
markmitch wrote:Not sure where to put this but since it is electrical in nature I thought here would be good.
Moved to electrical.
Mobile electronics is more along the lines of:
Topics: 106
Images: 437
Postby markmitch [OP] » February 14th 2020, 5:57pm
Thanks everyone, you too Will lol
Topics: 596
Images: 20
Extra Info: RS V8
Postby AstroWill » February 14th 2020, 7:47pm
You are most welcome, always trying to help out those in need.
Topics: 106
Images: 437
Postby Mmusicman » February 14th 2020, 8:00pm
My 2000, both upper hatch and lower doors BOTH have locking electronic solenoids.
They are controlled by toggle switch (on doors) or by key fob.
Upper hatch also has a mechanical key and electric pushbutton...
..lower doors do not (locks are only controlled by solenoid)
In other words, if the electronics fail, you're kind of screwed!
Firing on 5 Cylinders (L5)
Topics: 72
Images: 49
Postby Rod's TrucksRod's Trucks is online! » February 14th 2020, 8:12pm
"...controlled by toggle switch (on doors)" ?? 'Toggle switch'
Do you mean the Lock/Unlock key switch/push button, that I have to push to open the hatch on my '98.
Rod J
Topics: 19
Images: 47
Postby AstroWill » February 14th 2020, 8:18pm
The liftgate really doesn't 'lock', when it's 'locked' it really just disables the power to the actuator.
Topics: 106
Images: 437
Postby Mmusicman » February 14th 2020, 8:38pm
Rod's Trucks wrote:"...controlled by toggle switch (on doors)" ?? 'Toggle switch'
Rod J
Yes.. same thing by my definition, but you are correct.
It's a push button that toggles back/forth between lock and unlock.
Topics: 72
Images: 49
Postby MechBob » February 14th 2020, 8:50pm
Yes to all above,lol. If memory is correct, there were at least 3 different systems for astros with dutch doors, earlier ones did not unlock when other doors were unlocked, like Musicmans. However, i really was not going to get into that until Mark has them mounted and ready to wire. OK gotta run,bbl.
MechBob
Blue Status (L2)
Blue Status (L2)
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby markmitch [OP] » February 14th 2020, 9:05pm
I took the nuts off the inside of one of the doors that hold the u shaped mechanism in place so I got the doors apart but the u shaped part is still in the locking mechanism for the doors so I will have to figure out a way to power it and get it to release. I will not be installing these till I get the new seals and all that so I don't end up with a leaking situation, But thanks to all of you for the assistance. Mark
Topics: 596
Images: 20
Extra Info: RS V8
Postby markmitch [OP] » April 16th 2020, 4:23pm
I eventually had to cut the u shaped piece to get it apart, I went to a pnp and got the door locking mechanism and the u shaped part for10 bucks. However I do need color codes for the switch wires if anyone has access. I had written all the info down prior to cutting the harness to get it out of the dash but I seem to have lost the written down stuff. The manual does not show wiring for the three switches, ie, push to pop hatch, wiper, and rear defrost. If anyone has access I would appreciate it. Meanwhile I will be building a console to mount the three switches. Thanks Mark.
Topics: 596
Images: 20
Extra Info: RS V8
Postby sixsix » April 16th 2020, 9:42pm
I am on it, Mark.
See if you can see these w/ enough detail - I can zoom in on any detail you need. Got nothing else to do ...
Pg 156 - RR Window Defogger
Pg 157 - RR Window Defogger
You probably won't need these in Cal., but...
Pg 160 - RR Window W-W
Pg 161 - RR Window W-W
Pg 170 - RR Liftgate Release
Pg 171 - RR Liftgate Release
Pg 194 - RR Liftgate Components
Pg 195 - RR Liftgate Components
Hope these help.
Well, after all... what would Banacek say ?... “It is only a matter of time before armed citizens, waiting or not for the police, take things into their own hands, fire on the rioters for personal and property prot. & end up hunted like dogs.”
Firing on 2 Cylinders (L5)
Topics: 37
Images: 1269
Postby sixsix » April 17th 2020, 12:41am
I can't get those to zoom in correctly.
Try these:
And those suck, too - they expand to full size, but my photos suck here on these terribly.
I will shoot them in natural light tomorrow and use our Nikon. If it's not raining.
Topics: 37
Images: 1269
It is currently September 24th 2020, 6:57am
Time: 5:39pm
Date: Sep 22 '20
Time: 8:04pm
Gabor Latte
Comments: 19
Date: Sep 18 '20
Time: 9:37pm
Date: Sep 16 '20
Time: 1:08am
Attached by: WinnieVan
WinnieVan
Date: Aug 28 '20
Time: 10:45pm
Users browsing this forum: Google Adsense [Bot], Yandex [Bot] and 8 guests
