Starter wiring
Starter wiring
Postby Greenacarina [OP] » February 8th 2020, 2:23am
Hello!
Recently had my battery die in my 86 Astro. Put in a new one, now I get no crank. Voltmeter shows 12 volts, doesn't go down when I turn the key to start, tried shifting from Park to neutral...no change.
I have a FSM...somewhere...can't find it when I need, of course.
Hoping someone can tell me where the starter wire comes thru the firewall and the path it takes to get to the starter (and color).
I want to see where I am not getting power.
Thanks in advance!
Chris
Greenacarina
Years of Membership: Greenacarina has been a member for 2 full yearsGreenacarina has been a member for 2 full years
Van Model Year: 1986
Extra Info: Ce
Re: Starter wiring
Postby Big_kidBig_kid is online! » February 8th 2020, 3:39pm
Checked fusible links yet? Also look at the connector behind the battery. If it was OK before the battery swap, it would be highly coincidental for the switch to go at the same time.
Firing on 6 Cylinders (L7)
Topics: 185
Images: 331
Extra Info: 2WD 5.7 V8
Re: Starter wiring
Postby Greenacarina [OP] » February 8th 2020, 6:14pm
I did check the 2 fusible links behind the battery...they tested good. I do not suspect the ignition switch, I am quite sure something under the hood got disturbed.
Without a wiring diagram it's purely a guessing game :(
Greenacarina
Extra Info: Ce
Re: Starter wiring
Postby Big_kidBig_kid is online! » February 9th 2020, 1:37am
I THINK your diagram is on this page:
https://www.autozone.com/repairinfo/rep ... 52800a824a
Topics: 185
Images: 331
Re: Starter wiring
Postby Greenacarina [OP] » February 9th 2020, 5:34pm
Thanks for the diagram!
Looks like there is a relay I need to check. Can anyone tell me where I might find that?
Thanks!
Chris
Greenacarina
Extra Info: Ce
It is currently September 19th 2020, 2:05pm
Gabor Latte
Comments: 13
Time: 9:37pm
Date: Sep 16 '20
Time: 1:08am
Attached by: WinnieVan
WinnieVan
Date: Aug 28 '20
Time: 10:45pm
Date: Aug 27 '20
Time: 9:51pm
thenextdon13
Date: Aug 28 '20
Time: 3:09am
