Power windows and power acc circuit breaker
Postby GSouthee [OP] » March 25th 2020, 6:58pm
Hi fellas
Any idea what would make the circuit breaker trip when the power windows are used, mainly if used down then back up within a few seconds like when paying a toll?
Also what else is on the circuit breaker ie what power accessories? looked in the Haynes manual not much ruddy use.
Oh my wheels are a 1999 Astro tintop passenger van LT.
Cheers
G
Nothing cannot be fixed sometimes just needs imagination, help and a bloody big hammer!
GSouthee
Topics: 5
Images: 3
Extra Info: LT 4.3 AWD Tintop
  • Adding a buzzer for "check gauges" circuit (technical)
    by nerdybiker » June 2nd 2020, 2:24pm in Electrical
    Last post by nerdybiker View the latest post
    June 30th 2020, 12:39pm
  • No Power to Tow Harness
    by SportsBoy » July 16th 2020, 8:10pm in Electrical
    Last post by SportsBoy View the latest post
    July 26th 2020, 2:25am
    80
    October 21st 2020, 2:50pm
Re: Power windows and power acc circuit breaker
Postby Mmusicman » March 25th 2020, 7:24pm
Common problem with the electric windows.
Mine is doing the same thing (again).
I find I can "help" it up.. but it will keep getting worse.
The load resistance of the window coupled to a worn motor means it's drawing excessive current (more than it should)... which trips it's internal breaker. Lubing the mechanisms and tracks can help.. but only a little. Spray silicone works nice in the tracks.
The "circuit breaker" is built into the motor.
I believe it is actually designed for the auto roll down function... trips when window reaches bottom and stops moving.
Buy a new motor. They aren't too expensive.
They aren't too difficult to install either, other than drilling out some factory rivets.
You'll obviously have to pop the door panel.
Firing on 5 Cylinders (L5)
Topics: 72
Images: 49
Postby GSouthee [OP] » March 26th 2020, 5:59pm
Cheers for that mate,
However I was under the impression the windows CB was in the fuse box under the dash?
Will try the lubing first as the van was garaged for the last 3 years with very little use.
G
GSouthee
Topics: 5
Images: 3
Postby TBLBill » March 26th 2020, 6:52pm
Here's the only image I have of the power window circuit, which shows the breaker at the fuse box. Either way, I would replace the motor. Even if you get it to run, it'll probably be really slow and worth the $15 to change it.
TBLBill
Years of Membership: TBLBill has been a member for 2 full yearsTBLBill has been a member for 2 full years
Images: 42
Extra Info: LS RWD
Postby GSouthee [OP] » March 26th 2020, 7:12pm
Cheers bill,
That diag is much better than I have found and seems to be as I thought. Gonna give it a lube and then see what happens.
Will have a decko on web to see who can supply door motors to the UK. Poss Rock Auto?
Cheers again
G
GSouthee
Topics: 5
Images: 3
Postby AstroWill » March 26th 2020, 7:18pm
GM Techline eSI MiniXP OVA edition running in virtualbox has every wiring diagram and repair instruction for your van :) I have some links for setting up virtualbox and such in my signature/profile.
Topics: 106
Images: 438
Postby GSouthee [OP] » March 27th 2020, 4:45pm
Cheers Will not sure what all that means but will have a go.
GSouthee
Topics: 5
Images: 3
Postby AstroWill » March 27th 2020, 5:02pm
The GM Techline eSI is the GM Factory Service Manual for many vehicles, but in digital format. There is one floating around the web where it's already setup/installed/ready to run in a Virtualbox image(as an .OVA file).
Here is how to set up Virtualbox to run the prepackaged virtual machine: https://sites.google.com/site/astrosafa ... virtualbox
Might find some other interesting links there as well ;)
Let me know how you get on with it.
Topics: 106
Images: 438
Postby GSouthee [OP] » March 28th 2020, 4:26pm
Clearly I am dumb and not very tech savvy, but seem to have loaded VB. Now just cant work out how to get the file?
GSouthee
Topics: 5
Images: 3
Postby AstroWill » March 28th 2020, 7:21pm
I can give a tip or two.
Tip #1: Mediafire links look like this non-functional example: https://mediafire.com/file/klwj485sdf71s9dfs83s4s
Tip #2: 1+1=2
Topics: 106
Images: 438
Postby GSouthee [OP] » March 29th 2020, 4:20pm
Hi Will
Cheers mate, i used utorrent to download, took ruddy ages but all good, will work way through ti. Now to suss how to get printer to work with it.
Cheers G
GSouthee
Topics: 5
Images: 3
Postby AstroWill » March 29th 2020, 6:11pm
Awesome! Yea with bittorrent it all depends on others that are seeding the file, a lot of people don't do their part they just leech and run.
I like to set up shared folders in Virtualbox and the directions to install a PDF printer are listed on that Virtualbox setup page. If you print to PDF to a shared folder on the host, then you can open that on the host system and print it with whatever printers are on the host system.
If you run into any issues that aren't covered, feel free to message me.
Topics: 106
Images: 438
Postby Leeann_93 » March 29th 2020, 8:00pm
AstroWill wrote:I like to set up shared folders in Virtualbox and the directions to install a PDF printer are listed on that Virtualbox setup page. If you print to PDF to a shared folder on the host, then you can open that on the host system and print it with whatever printers are on the host system.
That's what I do, as well.
Postby GSouthee [OP] » March 30th 2020, 5:50pm
Well knock me down with a feather, it only ruddy works. Now I can take a hard copy down the garage with me.
Cheers all.
G
GSouthee
Topics: 5
Images: 3
Postby AstroWill » March 30th 2020, 6:27pm
Cheers! It is a great resource that will serve you well.
Topics: 106
Images: 438
It is currently October 21st 2020, 2:50pm
nwisehart
Date: Today
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Date: Oct 10 '20
Time: 4:52pm
Maddog
Date: Oct 09 '20
Time: 4:08pm
Users browsing this forum: Google [Bot] and 8 guests
