Battery cables cut during theft.
Postby BuckyBob [OP] » April 11th 2020, 1:38am
Hi. I've a 99 astro van. My battery was stolen, cut out the cables. Whats the name of the thing or things, cable assembly, etc, that i need to buy? I'd like to replace completely if thats possible.
I looked on rockauto but..
BuckyBob
Years of Membership: BuckyBob has been a member for 3 full yearsBuckyBob has been a member for 3 full yearsBuckyBob has been a member for 3 full years
Images: 4
Extra Info: v6 RWD
  • Power cut on freeway, but started right back up after?
    by kittenflaps » August 4th 2020, 10:04pm in Electrical
    September 26th 2020, 5:03pm
  • Best battery
    by Rinny » May 2nd 2020, 11:53am in Electrical
    June 3rd 2020, 1:51am
    9
    32
    October 27th 2020, 10:00am
Re: Battery cables cut during theft.
Postby albrow100 » April 11th 2020, 4:32am
The easiest way would be to go to a junkyard and extract both cables end to end out of an old harness and overlay it into your van.
Being careful to route it correctly
Another option is to buy aftermarket side post terminals and bulk wiring. A heavy duty crimper and various terminal ends and such
albrow100
Topics: 30
Images: 18
Extra Info: awd
Postby albrow100 » April 11th 2020, 4:33am
Also who cuts a battery out? That sucks
I’m sorry that happened
albrow100
Topics: 30
Images: 18
Extra Info: awd
Postby Rod's Trucks » April 11th 2020, 4:38am
That was pretty rude. How did they get into the engine compartment? Did the damage a lot of sheet metal, or just jimmy the latch?
As for the cables: I just looked at RockAuto. It appears they have it all.
There are listings for the cables, but it matters if it is AWD or RWD.
If you are goping to purchase the AC Delco cables, then you will need to decide if you want the basic cables ($10-$20 each), or the deluxe ( Professional set for twice the money, but better quality wire).
Nearly all of the listing have a picture, so you should be able to match up what you need to replace.
Rod
Rod's Trucks
Topics: 21
Images: 47
Alias (AKA): Rod and/or WE7X
Postby Bengt Weil » April 11th 2020, 4:45am
Rockauto link:
https://www.rockauto.com/en/catalog/chevrolet,1999,astro,4.3l+v6,1352933,electrical,battery+cable,2500
Everything you want is there. The most popular positive and negative cable sets are designated with the red hearts.
Bengt Weil
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Bengt Weil has been a member for 7 full yearsBengt Weil has been a member for 7 full yearsBengt Weil has been a member for 7 full yearsBengt Weil has been a member for 7 full yearsBengt Weil has been a member for 7 full yearsBengt Weil has been a member for 7 full yearsBengt Weil has been a member for 7 full years
Topics: 12
Postby Rod's Trucks » April 11th 2020, 4:56am
Sorry, I guess I misunderstood the question...you asked what the parts were called.
You will need a Positive battery cable ( + battery terminal to starter motor solenoid- usually Red color, but not always).
You will need a Negative battery cable, which goes to Ground ( Engine or Body frame - and always Black)
The Positive cable is referred to as Battery to Switch.
The Negative is Battery Negative or Battery to Ground.
While you are at it, you might want to look up the "Big 3" electrical cable upgrade reference. It might be a good time to ad the extra cable capacity if you run any significant accessories.
Rod
Rod's Trucks
Topics: 21
Images: 47
Postby AstroWill » April 11th 2020, 6:56pm
As linked above, you can buy the complete, assembled battery cables, or you can of course make your own. Just make sure everything is clean and tight and you should be good to go.
Topics: 106
Images: 438
Postby BuckyBob [OP] » April 19th 2020, 12:54am
Rod's Trucks wrote:Sorry, I guess I misunderstood the question...you asked what the parts were called.
Rod
Thank You Rod, yer a RockStar !
BuckyBob
Images: 4
Extra Info: v6 RWD
Postby BuckyBob [OP] » April 19th 2020, 12:56am
Bengt Weil wrote:Rockauto link:
Perfecto. Thank You ~
BuckyBob
Images: 4
Extra Info: v6 RWD
Postby BuckyBob [OP] » April 19th 2020, 12:58am
albrow100 wrote:Also who cuts a battery out? That sucks
Ya, my urban farm is in a hood. I had it parked in the driveway. Lotsta specialty tools stolen from inside - they jimmied the drivers door.
Apologies to all for not responding prior - I've been busy at the farm, planting seed, cutting back in the raised beds, re-connecting the rainwater collection systems, replumbing the beds... It's my first growing season since Harvey.
BuckyBob
Images: 4
Extra Info: v6 RWD
Postby BuckyBob [OP] » September 17th 2020, 7:32pm
Quick Update -
Bought a brand new set of the cables, and a brand new battery. Paid a mechanic to install the cables, just because.
Next is driver's side window replacement. I just set up an account online at LKQ PickYerPart and have some restoration plan ...
Thanks to all for answering my questions here - I really appreciate it !
BuckyBob
Images: 4
Extra Info: v6 RWD
Postby BuckyBob [OP] » September 17th 2020, 7:35pm
Rod's Trucks wrote: [snip]
Rod
Rod - that's what I got - a bigger cable - the original was bigger also - originally spec'd out as some OEM cargo beastie. Now to redo the stereo - but that's for next week :D
I really appreciate your answers here !
BuckyBob
Images: 4
Extra Info: v6 RWD
Postby AstroOafAdventurer » September 17th 2020, 8:29pm
Lazy thieves, they stole tools but couldn't properly disconnect the battery?!
What is this world coming to...
97 Astro Conversion Van 62k miles
AstroOafAdventurer
Topics: 28
Alias (AKA): Thorsteenster
It is currently October 27th 2020, 10:00am
Date: Today
Time: 4:29am
Comments: 9
Date: Oct 24 '20
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
