Spark then, ... NO SPARK!!!
Postby Definitive Arts [OP] » April 22nd 2020, 12:23am
HELP!
Helping my Dad get his 1995 GMC Safari back on the road. We put a new ICM, Coil, Cap and rotor in, reset the timing mark, and it turned over for us, twice. We ran it for a few moments then turned it off. Tried to restart it 5 minutes later and... no spark. Wouldn't start again. "?!?" Fuel pump is running, starter is turning over, but no spark. Went to investigate the electrical chain and the schematics in our Haynes manual shows a Crankshaft Position Sensor before the ICM and Coil, so I went to check it. ... no CPS, like my '98. Apparently, they switched over to CPSs mid '95 so this has the electrical system shown in the '94/'93' and earlier schematics. The only thing before the ICM and Coil is the ignition switch. We tested the pink power wire that goes to the Coil, from the ignition switch and ... no power. I dropped the steering column and checked the switch. ... the switch is good. "?" None of the schematics show a fuse in the fuse block or any inline fuses or fusible links. So, question is, ... why in the *&#@ did we suddenly lose spark and what failed on us?
Thanks!
Allen
Definitive Arts
Alias (AKA): Allen
  • sudden no start issue
    by 81SAFARIMATT » March 24th 2020, 6:43pm in Electrical
    March 24th 2020, 11:26pm
  • Intermittentish no run electrical problem (presumably)
    by fx4m » May 28th 2020, 1:53am in Electrical
    Last post by fx4m View the latest post
    June 8th 2020, 12:44am
    7
    80
    August 9th 2020, 6:05am
Re: Spark then, ... NO SPARK!!!
Postby gman » April 22nd 2020, 3:55am
I'm far FAR from an electrical expert or even someone who knows auto problems extremely well, but you might want to check if your astro/safari has a passlock system.
It's just another variable that can cut off your ignition.
1999 Chevy Astro Van
gman
Topics: 31
Images: 29
Extra Info: Base 4.3 RWD
Postby sixsix » April 22nd 2020, 2:57pm
And... of course, you know brand new parts go bad in the box. :cry:
Well, after all... what would Banacek say ?... “AOC - her astonishing matryoshka-like ignorance, like the rest of The Squad is surpassed only by the relentless idiocy of the democrats, antifa & it’s attendant mass media, mayors & governors.”
Orange Status (L5)
Orange Status (L5)
Topics: 36
Images: 1214
Postby Definitive Arts [OP] » April 22nd 2020, 9:16pm
This '95 does not have the Passlock System like my '98. :/
Definitive Arts
Alias (AKA): Allen
Postby AstroWill » April 23rd 2020, 3:49am
Passlock, if equipped would have nothing to do with the spark, it only disables the injectors.
Definitive Arts wrote:We tested the pink power wire that goes to the Coil, from the ignition switch and ... no power. I dropped the steering column and checked the switch. ... the switch is good. "?" None of the schematics show a fuse in the fuse block or any inline fuses or fusible links.
I think you may have found why you have no spark. Every circuit other than the starter has some kind of circuit protection, fuse/circuit breaker/fusible link. This one would be fusible link B, 15cm from connector C198, behind the battery bolted to the passthrough.
Please post the first half of your VIN number.
Topics: 106
Images: 437
Postby gman » April 23rd 2020, 6:33am
AstroWill wrote:Passlock, if equipped would have nothing to do with the spark, it only disables the injectors.
Are you getting all of this information from the vehicle wiring diagrams?
I really have to learn how to read those in depth.
gman
Topics: 31
Images: 29
Postby AstroWill » April 23rd 2020, 6:41am
Yes, comes directly from the FSM.
If it were for your 99, you could get the GM Techline eSI online and run it in virtualbox(check my sig/profile for links), but there are some full scanned FSMs out there floating around the web for some of the earlier years.
Topics: 106
Images: 437
Postby MechBob » April 23rd 2020, 7:14am
YA, whatever, interesting posts.Without voltage and current tests, means nothing .Please check the plug in connector. behind the battery, where the circuits pass through the firewall.A very well known trouble spot.
MechBob
Firing on 8 Cylinders (L1)
Years of Membership: MechBob has been a member for 1 full year
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Definitive Arts [OP] » June 18th 2020, 1:17am
Thank you for the help.
So, update. After having to work on other projects, we have returned to tackle this issue. There was a concern about the timing being out and the chain skipping a tooth, or something, so we removed the timing chain cover and found the chain was very worn out with a lot of slack but had not jumped a tooth. We replaced it with a new chain and mechanically set the timing. We also replaced the coil, ignition control module, cap and rotor, and wires, to be sure we had everything covered. Gave it a crank and it started up but had a hard time idling. It died, then, like before, would not start again. Checked spark off the coil and nothing. Hooked a meter to the pink wire coming to the coil and when the key is engaged, it shows power so, either the coil or the ICM went out again. Ugg... This is the 4th coil and the 4th ICM we have put in it and we still can't figure out what is killing it.
I looked behind the batter to check the pink wire going to the coil and the finance link is still good. Not soft and squishy (see attached photo).
We did just hook a code reader to it, just to see if it could point is in the right direction, and the only things coming up were:
- #59 (TTS)
- #67 (Cruise)
- #81 (QDM B)
- #82 (QDM A)
The 1st half of the VIN is:1GKDM19W
Definitive Arts
Alias (AKA): Allen
Postby Definitive Arts [OP] » June 18th 2020, 1:26am
*clarification* we tested power coming to the coil as well as the pink wire going from the coil to the ICM, and we have power on both when the key is engaged.
Definitive Arts
Alias (AKA): Allen
Postby Definitive Arts [OP] » June 18th 2020, 6:50pm
SOLVED!!!
Soooo, digging through eeeeeeverything possible in the signal routing... we found the culprit. It was the distributor. Mire specifically,the pickup coil inside the distributor. When inspecting it closer, we noticed it was lose. It would work at first but after a short amount of running,
it would wiggle and kill the spark. We took a matching distributor out of my old 87 Astro and *bam*, started up first try. Now to tune it and take it for a test drive.
Definitive Arts
Alias (AKA): Allen
Postby sixsix » June 18th 2020, 10:23pm
Thanks for the Update - Glad you got it sorted.
Orange Status (L5)
Orange Status (L5)
Topics: 36
Images: 1214
It is currently August 9th 2020, 6:05am
Attached by: kittenflaps
kittenflaps
Comments: 18
Date: Aug 07 '20
Time: 12:46am
Sailing_Faith
Comments: 9
Date: Aug 06 '20
Time: 4:48pm
Attached by: bowtie262
bowtie262
Date: Aug 02 '20
Time: 8:41pm
Attached by: markmitch
Comments: 40
Date: Aug 01 '20
Time: 10:43pm
Attached by: Wokka
Wokka
Date: Aug 01 '20
Time: 11:13am
