High output altenator
Postby Rinny [OP] » April 28th 2020, 9:06pm
Looking to replace my 250 amp alternator that just crapped out. lil over 2 years old I believe. Looking for one that has good output at lower idle. Any help is appreciated.
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full years
Topics: 54
Images: 6
Extra Info: 5.7L NP236
  • Good High End Alternator?
    July 4th 2020, 2:16am
    74
    August 12th 2020, 5:35am
Re: High output altenator
Postby AstroWill » April 28th 2020, 9:20pm
I would go with a stock AD244 145amp.
Topics: 106
Images: 437
Postby Rinny [OP] » April 28th 2020, 9:36pm
Just checked and I got 3 yrs out of thelast one. 253 amps 156.00. Do you think I can do better?
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Topics: 54
Images: 6
Postby Rinny [OP] » April 28th 2020, 10:12pm
The ac delco d1-ad244-hd200 alternator is rated at 200 amps but costs about 379 delivered.
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Topics: 54
Images: 6
Postby Astrofarian » April 28th 2020, 10:26pm
I would EXPECT an AC Delco unit to last longer than 3 years like your present one. My question is, why do you need such a high output? 145Amps is a lot of zap, not enough for you?
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby Rinny [OP] » April 28th 2020, 10:29pm
With the elect fan, also a fan on the tranny cooler, Warn 12000lb winch, I might add a live well for fishing at some point? Just thought bigger is better, lol. Also might add another battery at some point to run the live well and segment it so it doesn't drain the Bat that runs the truck just in case.
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Topics: 54
Images: 6
Postby Rinny [OP] » April 28th 2020, 11:26pm
Might have jumped the gun. Moved some wires and it seems to be charging. Will have to delve into it tomorrow.
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Topics: 54
Images: 6
Postby AstroWill » April 29th 2020, 7:19pm
Even better if you don't have to replace the alternator. Fingers crossed.
Topics: 106
Images: 437
Postby jimi_lee » April 29th 2020, 9:41pm
A lot of shops will test the alternator for you... Also your battery...
jimi_lee
Fueling (5/8 tank)
Fueling (5/8 tank)
Years of Membership: jimi_lee has been a member for 2 full yearsjimi_lee has been a member for 2 full years
Images: 103
Extra Info: Awd
Postby Rinny [OP] » April 30th 2020, 1:56am
Going in for an AC tune up with in the next few days. I will have them test it.
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Topics: 54
Images: 6
It is currently August 12th 2020, 5:35am
Sailing_Faith
Comments: 17
Date: Aug 10 '20
Time: 2:17am
doogaloo
Comments: 17
Date: Aug 09 '20
Time: 8:52pm
Attached by: kittenflaps
kittenflaps
Comments: 18
Date: Aug 07 '20
Time: 12:46am
Sailing_Faith
Comments: 17
Date: Aug 06 '20
Time: 4:48pm
Attached by: bowtie262
bowtie262
Date: Aug 02 '20
Time: 8:41pm
