Rear hatch lock switch
Postby Rinny [OP] » May 5th 2020, 1:43am
I could not find the thread I read a couple of years ago. Don't even know if it was on here. If you are having trouble getting the hatch to open and have to almost bang the button to engage the actuator there is a fix.
1)remove the clips over the end of the inside handle
2) remove the handle
3) remove the screws that hold the interior hatch glass trim
4) remove the steel bar that holds the handle
5) remove the 2 bolts that hold the metal bar for the handle
6)remove the wiper arm from the outside of the hatch
7)remove the plastic nut from the wiper assembly
8) Back to the inside and remove the 2 bolts that hold the wiper motor, take the motor out and let it hang
9)remove the clip that holds the lock cylinder and unplug it from the harness
10) pull it out from the outside
11) MARK THE CYLINDER AND THE SWITCH FOR ALIGHNMENT, unclip the switch from the lock cylinder
12) MARK THE HOUSING AND THE TOP OF THE SWITCH FOR ALIGHNMENT, carefully stretch the plastic housing and pry the top oF the switch out of the housing
13) MAKE NOTE OF THE POSITION OF THE COPPER PEICE AS IT COMES OUT OF THE HOUSING
14) clean all the crud and scale off the copper piece (I used a wire wheel on my bench grinder)
15) clean the contacts in the bottom of the housing
16) if the button with the lock cylinder was loose you can stretch the spring a bit, I did and it is like new.
17) reassemble
Make sure it goes back together exactly as it came apart, Don't ask me why but it took an extra couple of hours :banghead: .
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full years
Topics: 56
Images: 6
Extra Info: 5.7L NP236
  • Rear wiper switch button
    by Olivier02 » October 11th 2020, 8:34pm in Electrical
    Yesterday, 6:45pm
  • 2004 Astro Cargo Van Power door Lock Problem / Questions
    by DD1 » October 9th 2020, 4:12am in Electrical
    October 14th 2020, 11:50am
    7
    90
    October 28th 2020, 7:08pm
Re: Rear hatch lock switch
Postby zzimmer3 » July 6th 2020, 6:31pm
Mine just started acting up this weekend. It will actuate once, but if I don't pull to open the hatch, I hit the button again, bit it acts like it's 'tired' and doesn't want to actuate fully, just halfway moves the rods. Will this fix that issue?
1994 2wd, 1998 2wd, 2000 awd, 2001 awd
zzimmer3
Years of Membership: zzimmer3 has been a member for 6 full yearszzimmer3 has been a member for 6 full yearszzimmer3 has been a member for 6 full yearszzimmer3 has been a member for 6 full yearszzimmer3 has been a member for 6 full yearszzimmer3 has been a member for 6 full years
Topics: 66
Images: 50
Alias (AKA): teddybear
Extra Info: LT AWD
Postby Rinny [OP] » July 8th 2020, 12:16am
worth a try. if not a new actuator should fix it. I would clean it up first.
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Topics: 56
Images: 6
Postby markmitch » July 8th 2020, 1:52am
I drilled a small hole on the clevice that the rods go into and added a cabled pull to the inside of the hatch. I can climb in through the slider and pull the cable to open it. I did this because I am still wiring the hatch stuff through relays and such so I do not have the battery hooked up at this time. I did not take pictures of this but I can later if anyone would like to see it.
Firing on 5 Cylinders (L6)
Topics: 608
Images: 20
Extra Info: RS V8
Postby augidog » July 8th 2020, 2:34am
markmitch wrote:I drilled a small hole on the clevice that the rods go into and added a cabled pull to the inside of the hatch. I can climb in through the slider and pull the cable to open it. I did this because I am still wiring the hatch stuff through relays and such so I do not have the battery hooked up at this time. I did not take pictures of this but I can later if anyone would like to see it.
if you're offering pics of the internals, where you connected your ripcord, I'm in.
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Postby markmitch » July 8th 2020, 5:19am
I will take the door panel off and grab a few pics tomorrow, if you don't see them posted remind me please.
Topics: 608
Images: 20
Extra Info: RS V8
It is currently October 28th 2020, 7:08pm
Time: 4:29am
Date: Oct 24 '20
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
