rear door plug ID?
rear door plug ID?
Postby markmitch [OP] » May 11th 2020, 2:02am
Ok so I am close to being done with the barn door to dutch door fiasco but I seem to have a plug inside the rear passenger door that I can't find in my notes I added a couple pictures of it so if anyone know what is for please let me know. It is inside the door as I said but nothing plugs into it?
Firing on 6 Cylinders (L6)
Topics: 615
Images: 20
Extra Info: RS V8
  • Unknown plug connector on 05 GMC Safari
    by nwisehart » October 21st 2020, 12:45am in Electrical
    October 21st 2020, 4:06am
  • 2000 Astro rear Dutch Door won't open
    by mglsite » November 16th 2020, 8:21pm in Electrical
    November 24th 2020, 2:05am
    7
    41
    December 4th 2020, 8:15am
Re: rear door plug ID?
Postby Unclebilly » May 11th 2020, 2:26am
I have the same plug in my Dutch door and it’s not plugged into anything. It was just hanging there. I’m pretty sure it’s for a door lock actuator in the barn doors.
Unclebilly
Van Model Year: 2002
Postby markmitch [OP] » May 11th 2020, 4:19am
Oh ok well thanks a lot I thought maybe I missed something from the donor van.
Topics: 615
Images: 20
Extra Info: RS V8
Postby Astrofarian » May 11th 2020, 1:37pm
markmitch wrote:Oh ok well thanks a lot I thought maybe I missed something from the donor van.
I THINK that "UncleBilly" meant that you don't NEED it? Unless I'm wrong, would there be any reason to "Lock" the passenger-side swingy door when the hatch is locked and preventing the bottom doors from opening? This is a detail that I've never really given much thought to until now; I hope you find a definitive answer to this and post it up for us Mark.
-M!ke-
EDIT: Maybe you could plug your test-light into it and cycle the lock/unlock switch a few times?
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
Postby Rinny » May 11th 2020, 1:48pm
I just took that door apart and I do believe rom memory it was the actuator plug. It just makes the closure more secure and will not allow the door to be unlatched when the vehicle is locked so there is no slop in it if it was opened when the rest of the van is locked.
03Astro AWD/4WD
TorsenDiffs,3:73'S,VettServo
NP236TC
Dual Piston Rear Calipers
GY DTrac 235/85/R16
ARB &/Custom bumpers
2x6x1/4 Rockrails
Rinny
Years of Membership: Rinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full yearsRinny has been a member for 4 full years
Images: 6
Extra Info: 5.7L NP236
Postby augidog » May 11th 2020, 2:30pm
-M!ke-
more coffee-talk...I don't have any way to unlock my dutch doors except the key lock or dash button, meaning once the liftgate is latched the doors are locked. I have to agree that the unused plug is likely there for the barn door actuator, and that if you really wanted to know the test light would probably tell you.
augidog
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
Postby markmitch [OP] » May 11th 2020, 3:06pm
I still have to wire all the switches and wiring harness for the hatch before I can test that plug. That is why I asked in the forum. I ordered this so I can unplug the switches to move the console I built to house the switches if I ever need to get into the dog house. https://www.walmart.com/ip/seort/931058213
Topics: 615
Images: 20
Extra Info: RS V8
Postby augidog » May 11th 2020, 3:43pm
markmitch wrote:I still have to wire all the switches and wiring harness for the hatch before I can test that plug. That is why I asked in the forum. I ordered this so I can unplug the switches to move the console I built to house the switches if I ever need to get into the dog house. https://www.walmart.com/ip/seort/931058213
that's always good reasoning, quick-connections.
my 95 may or may not have the same mystery plug inside the door, and I don't care until i have to, so i was just gabbing with my morning smoke. what i know about this place is, the person who knows your answer will be along, and i'll wanna know too, just because.
augidog
Topics: 16
Alias (AKA): Augie
Postby AstroWill » May 11th 2020, 7:25pm
Should be in the component location views in the FSM.
My guess would be the key lock switch that the dutch doors don't have.
Images: 443
Postby Rinny » May 11th 2020, 11:25pm
AstroWill wrote:Should be in the component location views in the FSM.
Just removed the actuator from the dutch door. No key but it does lock.
03Astro AWD/4WD
NP236TC
GY DTrac 235/85/R16
2x6x1/4 Rockrails
Rinny
Images: 6
Postby markmitch [OP] » May 13th 2020, 5:14pm
I still have the barn doors with the type of windows that hinge open if someone close by wants to grab the windows and hardware they are free for the taking doors and all if needed. Anyone here know how to wire in relays so the dash light harness can be used to light the switches without blowing fuses, I could use the knowledge from someone.
Topics: 615
Images: 20
Extra Info: RS V8
Postby MechBob » May 14th 2020, 12:25am
Mark, you really should not need a relay to light the switches, unless you have some strange switches
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
It is currently December 4th 2020, 8:15am
Dbleeger
Comments: 14
Date: Nov 27 '20
Time: 11:29pm
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
