Question about the starter
Postby bradaskins [OP] » June 1st 2020, 7:43pm
Hi,
I pulled out the old starter. I'm having a hard time putting in the new one. One of the wires is really really short.
Is it ok to extend them? Wondering why they are so short.
Two wires go to one post and the hot goes to another post.
What are the gauges of the two wires?
Or do I have my wiring mixed up?
Also, do the wires need the plastic sheath?
bradaskins
Years of Membership: bradaskins has been a member for 1 full year
Topics: 41
Alias (AKA): Breaking Brad
  • electrical question for you smart guys
    by markmitch » March 30th 2020, 12:32am in Electrical
    March 30th 2020, 3:20am
  • Fuel pump question??
    by dave1950 » May 4th 2020, 6:42pm in Electrical
    Last post by dave1950 View the latest post
    May 7th 2020, 12:04am
    7
    33
    September 19th 2020, 1:34pm
Re: Question about the starter
Postby Mmusicman » June 1st 2020, 8:43pm
Yes you "can" extend the 12awg "signal" wire.
Just be sure to solder the connection so it is reliable.
I actually have this wire on a very heavy duty single disconnect.
Firing on 5 Cylinders (L5)
Topics: 71
Images: 49
Postby bradaskins [OP] » June 1st 2020, 8:52pm
Is the second diagram correct or the first picture?
bradaskins
Topics: 41
Postby Leeann_93 » June 1st 2020, 10:51pm
The replacements are configured slightly differently from the old, but it is possible to reconnect without extending. I had to have my husband (yep, I'm a cheater) solder on a new end for the ring that goes on the smaller terminal because mine flew off into space when I touched it.
New AC Delco vs. old AC Delco
I don't have a shot of the wires connected where you can see them, but I do have this:
Postby bradaskins [OP] » June 1st 2020, 11:54pm
Thanks to who responded. It took way to long to put in the new starter. Laying on Concrete without a jack or car ramps. It's tight under there. I did manage to use the wires as they were but next time I'm making them longer so it's easier to attach and turn the nuts.
bradaskins
Topics: 41
Postby markmitch » June 2nd 2020, 12:31am
I actually have a block of wood just to set the starter on when I hook the wires up. so they are not being tugged on while doing them. But I had shoulder surgery so my arm does not like certain positions lol.
Firing on 4 Cylinders (L6)
Topics: 594
Images: 20
Extra Info: RS V8
Postby Leeann_93 » June 2nd 2020, 3:04am
bradaskins wrote:Thanks to who responded. It took way to long to put in the new starter. Laying on Concrete without a jack or car ramps. It's tight under there. I did manage to use the wires as they were but next time I'm making them longer so it's easier to attach and turn the nuts.
Your situation might actually be worse than laying on coroplast on top of gravel. I think I used ramps, but I might not have. Either way, it sucks....and that’s why I had my husband solder the new end - I can solder, but soldering over your head is different and he does it all the time for commercial HVAC.
Postby Astrofarian » June 2nd 2020, 2:00pm
Personally, I've always managed to get the starter re-installed without needing to extend the wires, but....good to know that the thought has crossed other people's minds. My experience has usually been that the wires are only too short when you're trying to connect them; if you're just unbolting the starter to access something else (Like a motor mount or exhaust manifold) then the wires seem more than long enough to allow the starter to slip out at the most inopportune time and KABONG you when you're pulling on a breaker-bar.
Glad you got it taken care of!
-M!ke-
Astrofarian
Alias (AKA): M!ke
Extra Info: Someday......
It is currently September 19th 2020, 1:34pm
Gabor Latte
Comments: 13
Time: 9:37pm
Date: Sep 16 '20
Time: 1:08am
Attached by: WinnieVan
WinnieVan
Date: Aug 28 '20
Time: 10:45pm
Date: Aug 27 '20
Time: 9:51pm
thenextdon13
Date: Aug 28 '20
Time: 3:09am
