Dielectric grease?? Yes—No?
Postby Lee in Mountain View [OP] » June 4th 2020, 8:57pm
Folks, what’s the consensus on using dielectric grease for spark plug/spark plug wires? If you use it, do you apply to the spark plug wire contacts? I’ve only used it for light bulbs that’s why i ask.
Thanks.........Lee in Mountain View
Last edited by Lee in Mountain View on June 4th 2020, 10:48pm, edited 1 time in total.
My Tow Vehicle!
Years of Membership: Lee in Mountain View has been a member for 4 full yearsLee in Mountain View has been a member for 4 full yearsLee in Mountain View has been a member for 4 full yearsLee in Mountain View has been a member for 4 full years
Topics: 24
Re: Dielectric grease?? Yes—No?
Postby Rod's Trucks » June 4th 2020, 9:34pm
Just keep in mind that 'Dielectric' grease is an insulator.
If you use it in a light bulb situation I am assuming you are trying use it to keep water out of the socket area, and/or reduce corrosion of the contacts.
It probably would not hurt anything in a physical contact like a plug wire connector or an electrical terminal, where there is a direct mechanical connection, but if there is any sort of a physical gap, it will act as an insulator, because that is just what it is. You need a solid electrical mechanical connection. Good quality lamp bases provide that, but corroded or old loose bayonet bulb bases may not.
Also, there are good products for helping park plug boots to release. After many mile in that environment, the boots often want to bond with the spark plug ceramic. The smallest tube will last a very LOOONG time.
YMMV
Rod
Rod's Trucks
Topics: 30
Images: 55
Alias (AKA): Rod and/or WE7X
Postby MechBob » June 6th 2020, 3:32pm
Dielectric grease will keep the boots from sticking to the spark plugs, easier to get off next time.Good plug wire sets even come with a package of it.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Lee in Mountain View [OP] » June 6th 2020, 3:37pm
Thanks for comments!
Cheers........Lee in Mountain View
My Tow Vehicle!
Topics: 24
It is currently January 28th 2021, 7:27am
Attached by: oneilldm
oneilldm
Comments: 9
Date: Today
Time: 4:39am
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
