Weird Electrical Quirks
Postby rstro [OP] » June 14th 2020, 11:41pm
I’ve got a weird electrical thang happening in my 2001 Cargo and was wondering if any of y’all knew what might be the cause.
The radio doesn’t turn on unless the lights are turned on. The head unit is an aftermarket installed by the previous owner. Some other electrical weirdness includes the flashers/blinkers blinking too fast, and also the heat doesn’t work/turn on.
Now I know the blower motor may be broken, I see it’s been replaced once before, and also I have read the resistor fries easy too.
I’m less concerned with turning the radio and heat on right now, and more want to just figure out the problem. Any clues?
rstro
Van Model Year: 2001
Extra Info: Cargo
  • Weird Short - Battery Draining after changing to LED Bulbs
    by ProblemCar » January 10th 2021, 5:16pm in Electrical
    Last post by ProblemCar View the latest post
    January 10th 2021, 9:44pm
  • Weird-No Start
    by Primusblack » January 20th 2021, 6:04pm in Electrical
    Last post by Ray M View the latest post
    Yesterday, 8:00pm
    22
    January 28th 2021, 2:24am
Re: Weird Electrical Quirks
Postby Big_kid » June 15th 2020, 12:35am
Sounds like thr radio is miswired, the blower resistor or switch needs checking/replacement (check the blower ground too), and you may have turn signal bulbs out. The flasher is designed to go faster or slower depending on whether its a front or rear is bulb out.
Firing on 7 Cylinders (L7)
Topics: 185
Images: 339
Extra Info: 2WD 5.7 V8
Postby rstro [OP] » June 15th 2020, 12:48am
My thoughts too about the radio. Thanks for chiming in.
All bulbs are working. I’m wondering if the fast flashers were a symptom of radio/headlight issue.
rstro
Extra Info: Cargo
It is currently January 28th 2021, 2:24am
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
