Change overhead spot lights
Postby bradaskinsbradaskins is online! [OP] » June 15th 2020, 3:20pm
I can take out the three screws to access the light but how do you replace the bulb?
Years of Membership: bradaskins has been a member for 1 full year
Topics: 41
Alias (AKA): Breaking Brad
Re: Change overhead spot lights
Postby Birdshake » June 15th 2020, 4:43pm
It’s snaps into that cup with the electrical connectors. You push up and twist/pop the housing out. Then there’s a little spot for a small flat head to pop the lens out. No need to take it all apart like that. It can be done while mounted in the van.
2005 4WD Astro Cargo
NP236 3.73 Eaton Posi
S10 HD Springs 3" blocks
245/75/16 BFG KO2
KYB Monomax
Birdshake
Years of Membership: Birdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full yearsBirdshake has been a member for 8 full years
Images: 19
Extra Info: 4.3 AWD
Postby bradaskinsbradaskins is online! [OP] » June 15th 2020, 5:02pm
Thank you for your response.
I finally got the bulb out with the push and twist. It looks like it's just one piece. The lens is attached, there is no way to pop off the lens.
Looks like I just need to replace the whole bulb unit.
The headliner is out of my van, I installed a roof rack. So nothing is mounted at this point.
Thanks again.
OK, I finally got the bulb out of the housing.
Topics: 41
Postby SportsBoy » June 16th 2020, 3:07am
I covered that with a decent amount of detail - maybe this will help if you have other questions - https://www.astrosafari.com/viewtopic.p ... &start=100
SportsBoy
Years of Membership: SportsBoy has been a member for 2 full yearsSportsBoy has been a member for 2 full years
Topics: 18
Images: 23
Alias (AKA): Blake
Extra Info: 4.3 AWD
Postby Birdshake » June 16th 2020, 3:51am
That glass bulb should just pull out of the black socket. If you’re replacing them with T10 leds you will need to trim them down so they fit through the reflector housing.
245/75/16 BFG KO2
KYB Monomax
Birdshake
Images: 19
Extra Info: 4.3 AWD
It is currently August 12th 2020, 3:56am
Sailing_Faith
Comments: 17
Date: Aug 10 '20
Time: 2:17am
doogaloo
Comments: 17
Date: Aug 09 '20
Time: 8:52pm
Attached by: kittenflaps
kittenflaps
Comments: 18
Date: Aug 07 '20
Time: 12:46am
Sailing_Faith
Comments: 17
Date: Aug 06 '20
Time: 4:48pm
Attached by: bowtie262
bowtie262
Date: Aug 02 '20
Time: 8:41pm
