alternator questions
Postby markmitch [OP] » July 6th 2020, 6:22pm
A while back my battery went dead, I replaced it with a new one then the new battery 3 months old started showing similar problems so I checked the alternator and it was showing 11.4 while running so of course I assumed I needed a new alternator. I removed my alternator and took it to Autozone to have it checked. On there machine it showed 13.3 volts and he checked it twice and said it passed. So I ordered a new plug for the harness that plugs into my alternator installed it and re installed the alternator. Jump started my van and it started right up. I removed the jumper cables and it stayed running but when I tested the alternator with my multimeter its only putting out 12 volts with engine running? Any idea whats going on here? How can it produce 13 volts on the machine at autozone yet only 12 on my engine?
Firing on 4 Cylinders (L6)
Topics: 596
Images: 20
Extra Info: RS V8
  • Good High End Alternator?
    July 4th 2020, 2:16am
  • New alternator and Cable install...Inline fuse size?
    by fleetline51 » July 26th 2020, 9:46pm in Electrical
    July 28th 2020, 11:16pm
    29
    September 24th 2020, 6:58am
Re: alternator questions
Postby Sailing_Faith » July 6th 2020, 6:25pm
Perhaps you have resistance in the cable from the alternator... ?
Sailing_Faith
Images: 5
Alias (AKA): s/v Faith
Extra Info: SLT 4.3l RWD G80
Postby markmitch [OP] » July 6th 2020, 9:13pm
are you referring to the cable from the alternator to the battery?
Topics: 596
Images: 20
Extra Info: RS V8
Postby chevymaher » July 6th 2020, 9:24pm
Autozone is a clown car for electronics. They told me the same thing I made them give me another one. I am on my 6th alternator of this lifetime warrentee. They offered to buy it back.
They only fix what is broke and sell it as refurbished. So you got a 200 thousand mile part with one new part in it.
Postby Sailing_Faith » July 6th 2020, 10:10pm
markmitch wrote:are you referring to the cable from the alternator to the battery?
Yes, as in the cable addressed in the “big 3 upgrade”.
Sailing_Faith
Images: 5
Postby Mmusicman » July 6th 2020, 11:19pm
markmitch wrote:I removed my alternator and took it to Autozone to have it checked. On there machine it showed 13.3 volts and he checked it twice and said it passed.
THAT'S TOO LOW!
Output should be minimum 13.8v to 14.5v max (ideally)
TRUE OUTPUT ALSO DEPENDS ON LOAD!
Have them check a NEW one and see how it compares. :D
Sounds like you have a bad alternator... but you sort of already knew that.
(assuming you are measuring running output voltage at alternator itself)
Firing on 5 Cylinders (L5)
Topics: 72
Images: 49
Postby markmitch [OP] » July 6th 2020, 11:49pm
yes I checked it at the bolt on the rear of the alternator. I decided to check the 12 gauge wire going from the alternator to the starter and it basically broke in my hand when I grabbed it. Possibly a short or maybe its causing an intermittent loss of electricity? Either way I replaced it and tomorrow morning I will put the starter back in and check it again.
Topics: 596
Images: 20
Extra Info: RS V8
Postby Big_kid » July 7th 2020, 1:07am
markmitch wrote:... the 12 gauge wire going from the alternator to the starter and it basically broke in my hand when I grabbed it...
There's part of the problem. You're on the right track.
Firing on 6 Cylinders (L7)
Topics: 185
Images: 331
Extra Info: 2WD 5.7 V8
Postby markmitch [OP] » July 7th 2020, 11:25pm
Its definitely got to be the alternator, I replaced all the wires new fusible link and still 10.5 volts when running. I guess you are correct chevy maher. Alternator is junk.
Topics: 596
Images: 20
Extra Info: RS V8
Postby sixsix » July 7th 2020, 11:30pm
markmitch wrote:Its definitely got to be the alternator, I replaced all the wires new fusible link and still 10.5 volts when running. I guess you are correct chevy maher. Alternator is junk.
Well... there you go !
Well, after all... what would Banacek say ?... “It is only a matter of time before armed citizens, waiting or not for the police, take things into their own hands, fire on the rioters for personal and property prot. & end up hunted like dogs.”
Firing on 2 Cylinders (L5)
Topics: 37
Images: 1269
It is currently September 24th 2020, 6:58am
Time: 5:39pm
Date: Sep 22 '20
Time: 8:04pm
Gabor Latte
Comments: 19
Date: Sep 18 '20
Time: 9:37pm
Date: Sep 16 '20
Time: 1:08am
Attached by: WinnieVan
WinnieVan
Date: Aug 28 '20
Time: 10:45pm
Users browsing this forum: Google Adsense [Bot], Yandex [Bot] and 10 guests
