2005 Astro Dome light will not cut off.
Postby EHustle [OP] » March 1st 2012, 12:23am
Hello Astro oowners..I need your help ..Having a issue with a 2005 Astro Cargo Van where the interior over head lights will not cut off ,doors open or closed ,when you push the overide button you can hear the relay under the panel click and have checked all the door pin switches , the roll type of panel adjust is not in the rolled up position,also disconnected the alarm( and the wires) that were connecting to the doors thinking there has to be anothe module between the override button relay and the light it self .Even looking for a wiring schematic of the interior light system..HELP
EHustle
Years of Membership: EHustle has been a member for 8 full yearsEHustle has been a member for 8 full yearsEHustle has been a member for 8 full yearsEHustle has been a member for 8 full yearsEHustle has been a member for 8 full yearsEHustle has been a member for 8 full yearsEHustle has been a member for 8 full yearsEHustle has been a member for 8 full years
Alias (AKA): E Hustle
Van Model Year: 1986
  • Power cut on freeway, but started right back up after?
    by kittenflaps » August 4th 2020, 10:04pm in Electrical
    September 26th 2020, 5:03pm
  • postition light not working properly
    by Danield » September 20th 2020, 8:59am in Electrical
    October 1st 2020, 6:45pm
    9
    October 21st 2020, 2:39pm
Re: 2005 Astro Dome light will not cut off.
Postby RECox286 » March 1st 2012, 4:35am
Sounds like a ground polarity wire in front of a door switch has shorted to the frame, which would cause the light to be on all the time.
Good hunting
Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby Rey » March 12th 2012, 5:55pm
I believe the RKE module is responsible for controlling the dome lights, that's where the relay you're hearing is located.
You should find the RKE module to the left of the stereo, mounted directly to the firewall. It's a small black box with a single harness connected to it.
Good luck, hope this helps.
1999 GMC Safari SLE with 97k miles. Original Engine/Transmission.
Rey
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Rey has been a member for 9 full yearsRey has been a member for 9 full yearsRey has been a member for 9 full yearsRey has been a member for 9 full yearsRey has been a member for 9 full yearsRey has been a member for 9 full yearsRey has been a member for 9 full yearsRey has been a member for 9 full yearsRey has been a member for 9 full years
Extra Info: 4.3L V6
It is currently October 21st 2020, 2:39pm
nwisehart
Date: Today
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Date: Oct 10 '20
Time: 4:52pm
Maddog
Date: Oct 09 '20
Time: 4:08pm
