Dutch Door keylock location, because I'm curious.
Postby augidog [OP] » July 11th 2020, 5:07pm
I was admiring this clean Astro RWD, when I realized the keylock is on the liftgate. I don't know squat about years or variants, this van had cladding. seems to me this location would be inconvenient because the 'gate has to pop open. is it in fact standard or did someone effect a custom fix? as I said...I'm curious, because I've never seen or noticed this here on A/S, or in real life.
I should have looked more closely at the lower door, because from this distance I could see a round feature under the handle where I'm used to seeing the lock. I didn't want to get any closer and make people think I was casing a vehicle in the parking lot, and I certainly didn't want to publish someone's plate number.
augidog
Years of Membership: augidog has been a member for 1 full year
Topics: 16
Alias (AKA): Augie
Extra Info: AWD High-Top
  • Bad Ground? Location of Major Grounds (related to ignition).
    by gman » June 4th 2021, 6:50am in Electrical
    June 6th 2021, 4:40pm
    July 26th 2021, 3:07am
Re: Dutch Door keylock location, because I'm curious.
Postby M_a_t_t » July 11th 2020, 10:09pm
Some of the newer vans had them. My 04 has it. Some put a back up camera in the spot the key cylinder is on our 95's.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Years of Membership: M_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full years
Topics: 29
Images: 113
Extra Info: cl rwd
Postby markmitchmarkmitch is online! » July 11th 2020, 11:00pm
My doors came from a 94 and the lock cylinder is in the stock location But since my plate box was broken and I got one from pnp it did not have the hole in the box for the lock I had to drill it out. So my guess would be the early years of the dutch doors was by the handle and the newer ones were closer to the wiper arm.
Last edited by markmitchmarkmitch is online! on July 11th 2020, 11:01pm, edited 1 time in total.
Firing on 1 Cylinder (L7)
Topics: 640
Images: 21
Extra Info: RS V8 AWD
Postby sixsix » July 11th 2020, 11:01pm
augidog wrote:I was admiring this clean Astro RWD, when I realized the keylock is on the liftgate. I don't know squat about years or variants, this van had cladding. seems to me this location would be inconvenient because the 'gate has to pop open. is it in fact standard or did someone effect a custom fix? as I said...I'm curious, because I've never seen or noticed this here on A/S, or in real life.
Haha... sounds like us ... never get out.
"1 Nautilus died, BLM spawned, Antifa runs amok
- CRT & unions have taken schools by storm
THEN:
Not a single "Black" "Leader" condemns Black Crime
- White Supremacists get blamed for it all - they sure do get around"
Purple Status (L6)
Purple Status (L6)
Years of Membership: sixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full yearssixsix has been a member for 7 full years
Topics: 39
Images: 1411
Postby augidog [OP] » July 12th 2020, 1:03am
although becoming a pro about these isn't in my cards, I do enjoy picking up on the little details here and there, the key location is a change I would not have expected and can't imagine why it took place. thanks for taking a moment, folks.
augidog
Topics: 16
Alias (AKA): Augie
Postby MechBob » July 12th 2020, 1:55pm
Augi, was probably moved up for customer convenience.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby augidog [OP] » July 12th 2020, 5:30pm
MechBob wrote:Augi, was probably moved up for customer convenience.
I figured as much. being tall I could handle less stooping over. but seeing as the 'gate has to pop when you hit the actuator, I don't think I'd like the new location.
anyhow...now that I noticed this one, I've noticed the same on a couple other A/S's that pass through town.
augidog
Topics: 16
Alias (AKA): Augie
Postby M_a_t_t » July 12th 2020, 5:52pm
augidog wrote:I figured as much. being tall I could handle less stooping over. but seeing as the 'gate has to pop when you hit the actuator, I don't think I'd like the new location.
Does the cylinder on your 95 open the hatch?
1995 Mercury Tracer
M_a_t_t
Topics: 29
Images: 113
Extra Info: cl rwd
Postby augidog [OP] » July 12th 2020, 7:04pm
it does. plus the dash button. but no mechanical failsafe, like the ripcord method markmitch put on his dutch door conversion.
augidog
Topics: 16
Alias (AKA): Augie
Postby augidog [OP] » July 12th 2020, 7:06pm
it does. plus the dash button, which works only in P or N. the lower doors don't lock but are held closed when the 'gate is closed. but no mechanical failsafe, like the ripcord method markmitch put on his dutch door conversion.
augidog
Topics: 16
Alias (AKA): Augie
Postby M_a_t_t » July 12th 2020, 7:09pm
Interesting. Mine doesn't. I guess I need to add that to the fix it list. :(
1995 Mercury Tracer
M_a_t_t
Topics: 29
Images: 113
Extra Info: cl rwd
Postby augidog [OP] » July 12th 2020, 7:22pm
M_a_t_t wrote:Interesting. Mine doesn't. I guess I need to add that to the fix it list. :(
it's a simple grounding switch, so once you access it troubleshooting and repair should be easy. connector #170 is where you'd tap in for a hidden outside button.
edit: I changed it from "will be easy" to "should be easy." you know, just in case.
augidog
Topics: 16
Alias (AKA): Augie
Postby M_a_t_t » July 12th 2020, 7:58pm
augidog wrote:edit: I changed it from "will be easy" to "should be easy." you know, just in case.
Good. You almost jinxed me. :rolling: :ty:
1995 Mercury Tracer
M_a_t_t
Topics: 29
Images: 113
Extra Info: cl rwd
Postby MechBob » July 12th 2020, 8:08pm
Augi,seems to me the right lower door has a lock solenoid,built into the latch,that unlocks when lift gate is unlocked.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby augidog [OP] » July 12th 2020, 8:19pm
MechBob wrote:Augi,seems to me the right lower door has a lock solenoid,built into the latch,that unlocks when lift gate is unlocked.
nope, at least not on mine. there are no real "locks" but only a chinese puzzle...liftgate latched secures the lower doors. 'gate has relay-activated actuator, lower doors each have a mechanical release. you can in fact tug on the lower right handle and it will try to open but physically cannot with the 'gate down.
augidog
Topics: 16
Alias (AKA): Augie
Postby M_a_t_t » July 12th 2020, 8:25pm
This doesn't make sense. Also I can open the lower doors with the hatch shut until the inside lip hits the latched hatch.
Mine might be messed up, so it maybe it's not supposed to be that way. :confusion-shrug:
Augi responded as I was typing.
1995 Mercury Tracer
M_a_t_t
Topics: 29
Images: 113
Extra Info: cl rwd
Postby augidog [OP] » July 12th 2020, 8:31pm
no...YOU responded while I was typing. I think. now my head hurts...
augidog
Topics: 16
Alias (AKA): Augie
Postby MechBob » July 12th 2020, 8:51pm
Well,if van did not have one, there would be no need for the liftgate module,or the liftgate strut switch.I bet you have them, and they are not working.Latch assembly would look like this,the black is the electrical part.---- https://www.rockauto.com/en/moreinfo.php?pk=10163248
Next time you pull a panel, look and let us know.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby M_a_t_t » July 12th 2020, 9:06pm
I just pulled a panel. It was there, glued on though. Maybe a PO broke it? :shrug:
1995 Mercury Tracer
M_a_t_t
Topics: 29
Images: 113
Extra Info: cl rwd
Postby MechBob » July 12th 2020, 9:13pm
The electrical part is available separately,also.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
It is currently July 26th 2021, 3:07am
zz88008
Time: 8:09pm
OldSchoolNoe
Date: Jul 23 '21
Time: 8:34pm
Rockridge
Date: Jul 13 '21
Time: 11:08pm
silverastro
Date: Jul 04 '21
Time: 2:35pm
SoccerMom4x4
Date: Jul 02 '21
Time: 6:21pm
Users browsing this forum: No registered users and 15 guests
