Turning off Daytime Running Lights
Postby Mr.P [OP] » August 2nd 2020, 6:13pm
Hi folks, New member here. I was wondering if some of you might have an answer to my problem.
I have a 1999 Astro LS. I bought it used, and the Daytime Running Lights have never worked. I am not a fan of DRL, so I just let things be.
Recently, I decided to install some low beam LED headlights to improve night time visibility. They are direct plug in replacements for the 9005 Halogen so no modification was done to the wiring. The high beams are still regular halogen lamps.
The LED lights work quite well, but I have noticed something unusual. When the headlight switch is "off" and the engine is running, the low beam LED lights "Strobe" very dimly, turning on and off a couple times a second. This occurs regardless of it being day of night. Once the headlights are turned on, they work as normal with no flickering or other problems. I am almost certain the "Strobing" is caused by the DRL system.
I would like to disable the DRL system. I have searched the web, and the "push the dome light override 4 times" doesn't work, and I cannot see a fuse labled "DRL" in the #15 position in the fuse box to remove.
Is there a east way to permanently turn of the DRL?
Mr.P
Extra Info: LS RWD
Re: Turning off Daytime Running Lights
Postby Mr.P [OP] » August 7th 2020, 5:30am
*UPDATE* My mistake. I must have missed it the first time, but there is a fuse marked "DRL" in the fuse box under the dash. Pulled the fuse- no more "strobing" The headlights function like normal in manual mode.
Mr.P
Extra Info: LS RWD
It is currently March 2nd 2021, 3:19pm
OldSchoolNoe
Comments: 0
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
