Need some help!
Need some help!
Postby 90astro [OP] » August 10th 2020, 12:47am
Hi,
I own a 1990 chevy astro LT 4.3 V6.
I am having trouble with my door locks from the inside.
On the drivers side I can lock the door but when I go to press the unlock button nothing is happening.
On the passenger side both lock and unlock is not working.
I need some advise!!
Thank you :confused:
90astro
Alias (AKA): Joe
Van Model Year: 1990
Extra Info: LT
  • Temp, fuel, some lights working/not on dash
    by Hiker2187 » October 21st 2020, 5:20pm in Electrical
    October 22nd 2020, 7:13pm
  • HELP! TPS and MAP sensor connection mistake?!
    by observer » November 19th 2020, 8:19am in Electrical
    Last post by dcsleeperdcsleeper is online! View the latest post
    November 20th 2020, 9:00pm
    46
    March 4th 2021, 10:11am
Re: Need some help!
Postby M_a_t_t » August 10th 2020, 3:21am
Do they lock manually?
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Years of Membership: M_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full years
Topics: 27
Images: 96
Extra Info: cl rwd
Re: Need some help!
Postby 90astro [OP] » August 10th 2020, 4:24am
yes they do
90astro
Alias (AKA): Joe
Extra Info: LT
Re: Need some help!
Postby Leeann_93 » August 10th 2020, 11:11pm
Either the switches are bad (unlikely for both to be bad), you have broken wires in the door, or your door jamb switches aren't working properly.
On my '05, it was a combo of an intermittently-bad lock switch in the driver's door plus a bad door jamb switch (I've always called it a door pin switch, but GM says door jamb switch). With the passenger door switch not working right too, though, I'd swap the driver's switch into the passenger and see if anything changes (and vice versa). If it still acts the same, nothing swaps from driver side to passenger side, the switches probably are fine and you need to look at wiring and the door jamb (pin) switches.
Re: Need some help!
Postby 90astro [OP] » August 11th 2020, 2:43am
ok I will definitely try that out! Thank you!
90astro
Alias (AKA): Joe
Extra Info: LT
It is currently March 4th 2021, 10:11am
OldSchoolNoe
Comments: 0
Date: Mar 01 '21
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 22
Date: Feb 17 '21
Time: 4:26am
