PCM Electronic Fan Control...
Re: PCM Electronic Fan Control...
Postby AstroWill » November 3rd 2020, 7:08pm
stent wrote:looking online, found this for sensor thread size :
got the OEM part number from amazon, confirmed it on GMPartsDirect.com as fitting 2000 camaro.
:wave:
GM 13587697 ACDelco 15-51342 https://amzn.to/3l71OW8
Would be awesome if it works for $30
Topics: 109
Images: 481
  • I bought a 2 speed e fan-need help wiring please
    by markmitch » March 20th 2021, 10:12pm in Electrical
    March 25th 2021, 5:26pm
  • E-Fan Issues
    by Brewtus » May 13th 2021, 11:03pm in Electrical
    Last post by Brewtus View the latest post
    June 1st 2021, 9:30pm
    81
    June 25th 2021, 11:23am
Postby stent » November 3rd 2020, 11:21pm
WinnieVan wrote:Would be sick if someone added AC support....
credit to Mmusicman's camp-out post
credit to "ralph" steadman
Years of Membership: stent has been a member for 4 full yearsstent has been a member for 4 full yearsstent has been a member for 4 full yearsstent has been a member for 4 full years
Images: 188
Extra Info: rwd cargo
Postby stent » November 6th 2020, 4:57am
here's some pics of the camaro sensor from the JY :
Images: 188
Postby stent » November 20th 2020, 8:22am
this should be the weld in port for the sensor to attach to :
i don't know if there is a place on the van's ac where you could screw this fitting in - that would make it really easy !!!
:wave:
Images: 188
Postby AstroWill » November 20th 2020, 8:29pm
I like where this is heading!
Topics: 109
Images: 481
Postby stent » December 6th 2020, 6:56pm
i haven't forgotten about this thread but the JY selection of camaro's & firebird's here in denver is poor....
the best?? right now is this '98 firebird :
website pic of '98 firebird @ denver u-pull
not a good candidate for parts out of the nose.
Images: 188
Postby AstroWill » December 8th 2020, 5:42am
stent wrote:i haven't forgotten about this thread but the JY selection of camaro's & firebird's here in denver is poor....
LOL, yeah, might want to look elsewhere for AC parts :)
Topics: 109
Images: 481
Postby WinnieVan [OP] » December 8th 2020, 6:03am
This forum rocks.... great work!! Will be super slick if you can figure this out. You can do it!!
WinnieVan
Firing on 4 Cylinders (L3)
Years of Membership: WinnieVan has been a member for 4 full yearsWinnieVan has been a member for 4 full yearsWinnieVan has been a member for 4 full yearsWinnieVan has been a member for 4 full years
Topics: 66
Images: 27
Postby stent » December 9th 2020, 1:09am
the AC high side aluminum tubing outer diameter on my van is 3/8". the diameter of the JY camaro tubing i snipped off is also 3/8" at the pressure sensor, but on the evaporator side of the sensor the tubing bulges out to a larger size right after the sensor bung :
if i can find a sensor on a length of 3/8" tubing without the bulge, an alternative to having the sensor port welded to my high side tubing would be splicing in a piece of JY tubing with the sensor bung using 2 of these splice fittings :
dorman 3/8" splice fitting
link to Dorman splice fitting at amazon :
https://www.amazon.com/Dorman-800-641-D ... 1HFJYNNK7N
i have the plain, front only AC - the best place i see for locating the sensor is on the vertical section of the tube between the service port and the connection to the evaporator (left side of the picture between brass fitting and 90 degree bend) :
the unknown here is if there is enough straight length in the van tube to splice the section in.
i haven't tried to get a price for a shop to weld on a new bung, as compared to the price for 2 splice fittings.
the most professional installation would be to get a new line section and have the bung welded on to it.
new tube @ rockauto
link to new tube at rock auto :
https://www.rockauto.com/en/moreinfo.ph ... 33&jsn=934
both the splice method and bung-weld method of attaching the pressure port mean that the refrigerant must be evacuated.
before i commit to either of those choices, i want to try and find a t-fitting for the service port that i can use to mount the sensor to one outlet with some kind of adapter fitting. i don't know about hood clearance or how easy it would be to accidentally break the fitting off, but if a t-fitting could be made to work the refrigerant doesn't have to be evacuated, or the t-fitting could be considered temporary until the system HAD to be evacuated for some reason.
more stuff for the shopping list :
here's a dorman twin electric fan that is a direct fit replacement for a 2002 camaro with V8 (no connectors, relays or wiring harness included) :
dorman 2002 camaro fan
link to dorman fan at amazon :
https://www.amazon.com/dp/B001C6L5I2/re ... automotive
the large capacity 3-row welded aluminum radiators on ebay have come down in price :
radiator pic :
ebay 3-row radiator
link to radiator on ebay :
https://www.ebay.com/itm/3-Row-CORE-Alu ... SwcYxZjVAz
:wave:
Images: 188
Postby stent » February 9th 2021, 9:21pm
i got one of the welded aluminum radiators from ebay for $150.oo shipped. looks nice....
now i have something to plan the electric fan mounting around...
the 2 links below might be useful for this thread. the linked threads from performancetrucks.net and silveradosierra.com discuss adding electric fans controlled by the ECM to silverado/sierra trucks with mechanical fans.
according to the threads, 2005-06 silverado electric fan relays are mounted separately from the rest of the underhood fuse box and can be removed as a unit with the wiring attached for the ECM - i haven't seen what the 1998-2002 camaro relays & wiring look like & don't know yet if the silverado version would be something useful to use instead, so i added the links for future reference.
:text-link: https://www.performancetrucks.net/forum ... vy-484892/
:text-link: https://www.silveradosierra.com/under-c ... 1-130.html
pictures of the silverado efan relay unit & wiring (not mine, pics from linked threads) :
silverado relay assembly
:wave:
Images: 188
Postby WinnieVan [OP] » February 9th 2021, 9:54pm
CFM has a nice diagram of that three relay system... it's definitely robust and nice that it is outside the main fuse box.
WinnieVan
Topics: 66
Images: 27
Postby stent » February 9th 2021, 10:11pm
WinnieVan wrote:CFM has a nice diagram of that three relay system... it's definitely robust and nice that it is outside the main fuse box.
is the camaro/firebird relay setup a part of the main box ?
Images: 188
Postby WinnieVan [OP] » February 18th 2021, 12:18am
i'm not sure
WinnieVan
Topics: 66
Images: 27
Postby stent » April 6th 2021, 10:33pm
adding some links to fan kits for future reference....
:text-link: link to dorman fan kit for 2002 camaro :
https://www.amazon.com/Dorman-620-634-R ... let+Camaro
dorman fan kit #620-634 at amazon; $140.00
link to a radiator & fan combo on ebay :
:text-link: https://www.ebay.com/itm/114273234890?_ ... gIDs_D_BwE
ebay radiator & fan; fits 1996-2005 astro/safari; $198.00
:text-link: link to fan kit on ebay :
https://www.ebay.com/itm/160781874497?c ... gIPsPD_BwE
ebay twin fan kit; fits 1995-2005 astro/safari; $245.00
:text-link: link to derale twin fan kit at summit racing :
https://www.summitracing.com/parts/der- ... gIbVfD_BwE
derale fan kit at summit; $245.00
:text-link: link to flex-a-lite twin fan kit at amazon :
https://www.amazon.com/Flex-lite-298-Un ... 3842302316
flex-a-lite fan kit #298 at amazon; $351.00
:text-link: link to flex-a-lite fan mount kit for #292 fan at amazon :
https://www.amazon.com/Flex-Lite-29201- ... B003EOBO2M
flex-a-lite 29201 fan mount kit at amazon; $56.00
Images: 188
Postby dcsleeper » April 6th 2021, 10:52pm
Profile | Edit signature
"If you are at the poker table and can't figure out who the sucker is, you're it".
dcsleeper
Years of Membership: dcsleeper has been a member for 1 full year
Topics: 22
Images: 83
Alias (AKA): DC
Postby stent » April 6th 2021, 11:10pm
dcsleeper wrote:I'd like to have your pocketbook!
hi dcsleeper,
thanks for adding to the wish list!!
i am still hoping to get something out of the junkyard but haven't had any luck yet.......
grab of '99 astro radiators at 0'reilly auto parts, i included this for the core dimensions :
here's a grab to go with your reference to the cobalt/g5's, of 2009 g5 radiators at O'reilly with the core dimensions :
pic of the new radiator i got on ebay a while back :
ebay radiator i bought
the core dimensions are :
17-1/2" high.
28-1/4" wide.
2" thick.
the width across the outside edges of the tanks is 33-7/8".
a number stamped on the bottom : ZE-YP002-S88.
:wave:
Images: 188
Postby dcsleeper » April 6th 2021, 11:21pm
dcsleeper
Topics: 22
Images: 83
Alias (AKA): DC
Postby stent » April 23rd 2021, 4:34am
i think i've collected all of the pieces to hook together a working AC line pressure sensor from sensor to computer :
hi pressure line from condenser....in my van now. i plan on attaching the sensor somewhere along the vertical part of the tube in the left side of the picture
new hi pressure line
new pressure sensor & fitting to weld on the new hi pressure line
new fitting
new sensor
crude mockup of new parts with everything still in packaging : hi pressure line/weld in fitting/sensor
JY camaro sensor wiring harness with sensor connector, power feed to sensor, & sensor signal wire already terminated to plug into computer connector
JY 12200411 computer with connectors, from 2002 safari - hopefully this will be workable with the least amount of reprogramming. i got the computer mounting bracket/battery tray from the 2002 also
next i need to figure out the exact spot on the hi pressure line to attach the weld in fitting, make a dot on the tubing with a sharpie, & get a shop to weld it on.
then i need to get a JY silverado relay box & wiring to power up fans, decide on fans, & on & on.
:wave:
Images: 188
Postby WinnieVan [OP] » April 23rd 2021, 6:37pm
Honestly -- I'd just go with the volvo fan relay over the JY silverado box.... super easy and robust. You can easily use it to power a single fan or a double-fan.
I'm pretty sure I have one collecting dust in my parts box with pigtails! PM me if you're interested -- it's all yours for the price of shipping since I really want to see this build happen :)
WinnieVan
Topics: 66
Images: 27
Postby stent » April 30th 2021, 7:56pm
WinnieVan wrote:Honestly -- I'd just go with the volvo fan relay over the JY silverado box.... super easy and robust. You can easily use it to power a single fan or a double-fan.
thanks :ty: WinnieVan :ty: but i think i'll stick with the plan for the GM truck relay stuff - i still need to ditch my black box and get an "0411" ECM swapped in to make this all work the way i want in my '99 so bear with me......the weather's getting nice so i'll start haunting the JY websites for stuff again :wave:
Images: 188
PreviousNext
It is currently June 25th 2021, 11:23am
Comments: 64
Date: Jun 23 '21
Time: 6:52am
Ken2.7
Comments: 39
Date: Jun 18 '21
Time: 10:16pm
SoccerMom4x4
Date: Jun 17 '21
Time: 1:30am
joeg
Date: Jun 16 '21
Time: 11:56pm
Date: Jun 16 '21
Time: 10:47pm
cron
