no alt charge and engine idles only
Postby Astro plain jane [OP] » August 31st 2020, 9:15pm
I've got a problem with my 2005 Astro. The battery is not charging and the engine will only idle. It dies if it is accelerated. To test the alternator, I made a jumper harness to energize the alternator L terminal. I ran battery positive through a bulb to the L terminal. It then charged at 14 volts, and the engine ran fine, with full power. I guess the instrument cluster, PLC, or wiring could be the problem. How do I separate/ troubleshoot these?
Astro plain jane
Alias (AKA): Shovel
Extra Info: 2wd
It is currently March 1st 2021, 8:24pm
