Wiring fuel pump to connector, grommets through crossbeams?
Postby blendergasket [OP] » September 16th 2020, 7:34pm
Hi! I installed a new fuel pump and it care with a long wiring harness I traced to a plug beneath the van. The wiring harness goes through 2 crossbeams using plastic grommet things. I've tried finding them online but don't know the right words to search. The plastic seems very worn on them, and I'm worried if I pry them apart they will break.
What's the best way to deal with these? ?
Will I be able to reinstall them after I pry them off? Or will they need to be replaced. If they need to be replaced, what are they called?
Thank you in advance for your assistance.
1994 Astro Ext AWD
blendergasket
Years of Membership: blendergasket has been a member for 3 full yearsblendergasket has been a member for 3 full yearsblendergasket has been a member for 3 full years
Topics: 22
Alias (AKA): blendergasket
  • ICM & Ignition Coil Connector
    by OldSchoolNoe » January 30th 2021, 2:03am in Electrical
    January 30th 2021, 4:29am
  • Help identifying this connector
    by Jack.buster.05 » Yesterday, 5:31am in Electrical
    Today, 1:18am
    April 23rd 2021, 1:15pm
Re: Wiring fuel pump to connector, grommets through crossbea
Postby MechBob » September 17th 2020, 5:16am
Hey.They are rubber,with a bit of stiff internal backing,sometimes,on the lip.They are called "grommets".I doubt if you could find new ones.But,as they do not see the sun(uv) you usually can use them over,or even "patch" them with a bit of silicone sealer.I always hated the super long fuel pump harness on the earlier vans,was so stupid.OK,2 things,the connector that comes on the new "sender unit" or "fuel pump assembly" has the factory connector,with the old style round pins.Even if you pulled it and only replaced the fuel pump itself,then you have used this connector over,again.That round pin connector,at the long end of the harness,has been the cause of many intermittent problems, from poor connection.Over the years,I repaired quite a few.My 94,I did the cut the floor,added a connector,and,on that far forward connector, soldered the wires.Have seen others also do almost the same,but right down by the fuel filter,add a connector,and solder the front.Just food for thought.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby M_a_t_t » September 17th 2020, 5:38am
There are tabs on the backside. Squeeze them and you should be able to pull it out of the opening. Then you can open it up to remove the harness. That's all I had to do on my van.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD
1995 Mercury Tracer
2004 Chevy Astro AWD
2017 Kawasaki VersysX 300
M_a_t_t
Years of Membership: M_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full yearsM_a_t_t has been a member for 6 full years
Topics: 27
Images: 96
Extra Info: cl rwd
Postby blendergasket [OP] » September 17th 2020, 6:33am
Thank you for your replies. I got the grommets off and have the wiring harness mostly installed. I had to stop because it got dark but will complete it tomorrow. Thanks!
1994 Astro Ext AWD
blendergasket
Topics: 22
Postby MechBob » September 17th 2020, 6:52am
Awesome.i will say again,those round pin connectors were troublesome,many a person/vehicle had problems a day to months later,because pf poor connections,take a pin,or something,and bend down,tighten the contacts on the vehicle side of the connector.The terminals on your new sender are fresh, but do not restructure the body side terminals.
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby blendergasket [OP] » September 18th 2020, 5:06am
Thanks for the tips on that. My goal was to keep this as simple as possible so I balk at the idea of cutting the wires and creating more connectors, although I can see how it would keep me from having to restring the harness.
I attached all the hoses and strung the harness all the way to the plug but am having a little trouble with the little white clip holding it on. I tried to remove it with a pliers, but didn't want to break it. I'll keep working on it tomorrow and then when I get it open I'll be able to see what you are taking about with the terminals on the plug. I will check to see if I can bend them in a way that makes sense when I see them.
Thanks for all your kind help and advise.
1994 Astro Ext AWD
blendergasket
Topics: 22
Postby blendergasket [OP] » September 20th 2020, 1:26am
MechBob wrote:Awesome.i will say again,those round pin connectors were troublesome,many a person/vehicle had problems a day to months later,because pf poor connections,take a pin,or something,and bend down,tighten the contacts on the vehicle side of the connector.The terminals on your new sender are fresh, but do not restructure the body side terminals.
The round pin connectors looked perfectly centered in the holes they live in. Are you saying to bend them down slightly to they contact the slots better?
I got it all put together and no stalling on my first drive!
1994 Astro Ext AWD
blendergasket
Topics: 22
It is currently April 23rd 2021, 1:15pm
Comments: 37
Date: Today
Time: 3:30am
Attached by: Birdshake
Birdshake
Time: 4:13pm
Jack.buster.05
Time: 5:30am
Attached by: GaryMacGuyver
GaryMacGuyver
Date: Apr 10 '21
Time: 11:29am
Comments: 37
Date: Apr 06 '21
Time: 11:08pm
