Remove key in ignition chime
Postby Cooki_monstre [OP] » September 28th 2020, 10:48pm
I use my van lots as a "music" van. (All doors open for the extra sound).
I would very much like to remove the annoying chime that's given when
the key is in the ignition and the door is open. I've seen threads on this
before but after searching for a while I could not find any. I would like
to keep all the other chimes if possible. Thanks for any help! :D
Cooki_monstre
Alias (AKA): Jacob
  • Dead In The Water (no power to ignition)
    by 1992safari » August 24th 2020, 1:07am in Electrical
    August 25th 2020, 1:45am
  • Ignition switched power source under hood
    by snailsafari » September 4th 2020, 10:45pm in Electrical
    Last post by Sailing_Faith View the latest post
    September 6th 2020, 6:12pm
    9
    68
    October 28th 2020, 11:37pm
Re: Remove key in ignition chime
Postby AstroWill » September 29th 2020, 2:27am
Topics: 106
Images: 440
Postby sixsix » September 29th 2020, 4:56pm
I was about to say... scroll down the page.
There are 5 or 6 usually relevant or similar threads listed...
Here's that Thread Will referred you to.
I do not think that thread is very informative and the years mentioned may not work.
"remove the dash", etc, etc,
As far as searching - try: " chime disable 1998 astrosafari.com "
Including this site's addy in your search line will show you pertinent posts / threads without having to use the crappy search function of the site itself.
Well, after all... what would Banacek say ?... “Everything needs to change except the asshole culture and stupid way of life of the avg. antifa, BLM follower - slobs, cowards, killers w/o any thought that they, IN FACT, are now the Racists.”
Firing on 3 Cylinders (L5)
Topics: 37
Images: 1280
Postby AstroWill » October 1st 2020, 5:54pm
Cooki_monstre wrote:I use my van lots as a "music" van. (All doors open for the extra sound).
Another option would be to wire up a switch so that when enabled it appears that all of your doors are closed. Or wire the radio on a separate switch so that you can leave it on while having the key removed from the ignition.
Topics: 106
Images: 440
It is currently October 28th 2020, 11:37pm
Time: 4:29am
Leeann_93Leeann_93 is online!
Date: Oct 24 '20
Time: 3:02pm
donbenny1915
Date: Oct 23 '20
Time: 1:44am
nwisehart
Date: Oct 21 '20
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
