Rear wiper switch button
Postby Olivier02 [OP] » October 11th 2020, 8:34pm
Hi! The bulb in my switch is dead. Since these switches are no longer available brand new, is there a solution To change the led/halogen bulb in these 3 switches? Thanks a lot
Olivier02
Topics: 7
Alias (AKA): Olivier
Extra Info: SLT AWD 4.3L
  • Another Dutch door button issue
    by Wokka » August 1st 2020, 10:36am in Electrical
    Last post by Wokka View the latest post
    August 2nd 2020, 7:20am
  • Blower Motor, Wiper, Rt Turn Signal Dashlight GREMLINS
    by SlowRider » June 12th 2020, 9:06pm in Electrical
    Last post by SlowRider View the latest post
    June 14th 2020, 3:29am
    9
    84
    November 24th 2020, 6:52am
Re: Rear wiper switch button
Postby sixsix » October 11th 2020, 9:44pm
The switches may not be avail, but the Bulbs sure are.
At any rate, the switch is available in most JYs.
Don't limit your search to these vans, either - might X-ref to other GM models.
Well, after all... what would Banacek say ?... “May be hard to believe... President Trump should rest easy and concede what was in fact a foregone conclusion: Another OLD MAN won with only about 50% of the Change Believers/Fools showing up."
Firing on 4 Cylinders (L5)
Topics: 38
Images: 1303
Postby AstroWill » October 12th 2020, 2:16pm
Olivier02 wrote:Hi! The bulb in my switch is dead. Since these switches are no longer available brand new, is there a solution To change the led/halogen bulb in these 3 switches? Thanks a lot
Yep, you can simply replace them with incandescent or LED bulbs. Someone did a great write-up with lots of helpful pictures, but you would have to search for it.
Images: 443
Postby Leeann_93 » October 12th 2020, 10:54pm
Moved to Electrical
Postby stent » October 27th 2020, 6:16pm
if all 3 switch lights are out the problem might be in the power feed to the little lights.
Images: 188
Extra Info: rwd cargo
Postby AstroWill » October 27th 2020, 6:45pm
AstroWill wrote:Someone did a great write-up with lots of helpful pictures, but you would have to search for it.
https://www.astrosafari.com/viewtopic.php?f=13&t=119881
Images: 443
It is currently November 24th 2020, 6:52am
tungtide
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
Date: Nov 19 '20
Time: 7:31pm
