Alternator swap
Alternator swap
Postby Dannyboy93 [OP] » October 14th 2020, 7:03pm
Hey so i have an 05 astro with a bad alternator and im wondering if a swap with an earlier model astro will be compatible. As far as i know 05-09 astros are compatible but im looking at a 2001 astro. Does anyone know if i can use the 01 alternator?
Dannyboy93
Alias (AKA): Daniel
  • Good High End Alternator?
    July 4th 2020, 2:16am
  • alternator questions
    by markmitch » July 6th 2020, 6:22pm in Electrical
    July 7th 2020, 11:30pm
    9
    36
    November 24th 2020, 8:17am
Re: Alternator swap
Postby dchan51360 » October 14th 2020, 9:36pm
First of all, Welcome to the site.
Astros/Safaris were discontinued in 2005 (last model year)
The Gen 3 was 2002-2005.
IIRC the alternator was the same on Gen2 and Gen3 but I'm sure several people will either confirm or correct me on this.
But if you are swapping the alternator anyway, it may make sense to upgrade to an AD244. You can search for "upgrade Alternator" for more details.
DC
dchan51360
Firing on 7 Cylinders (L1)
Re: Alternator swap
Postby Dannyboy93 [OP] » October 15th 2020, 8:17am
Hey mate, thanks for the welcome and reply.
Ah thanks for clarifying the 05-09 thing, i was going off what my local pick and pull told me over the phone but its possible i misheard them.
Sounds promising in regards to gen2 and gen3 having the same alternator, I would consider an upgrade but for now i just need a quick fix and i can pick this 01 astro for next to nothing.
Dannyboy93
Alias (AKA): Daniel
Re: Alternator swap
Postby AstroWill » October 15th 2020, 1:33pm
The junk yard has an interchange manual and they are pretty darn accurate. Where the confusion comes in is that it's the same alternator on many vehicles between years. So yes, your 2005 Astro might use the same alternator as the 2007 Silverado/Express/Savana/ETC.
Generally, just go with whatever they say will be a direct fit and you will be good to go. However, that doesn't mean that you can't get other things to fit/work with some adjustments.
Using the GM parts sites, you can enter your VIN number and look up the exact alternator from your van.
Just a quick look by year says that this is your alternator, or at least what they have replaced it with :) https://amzn.to/33Y2Xcw
Yet another way is looking at your current alternator, there are numbers stamped on there, can cross reference those numbers.
Check out the link in my signature for some helpful parts links/info.
Images: 443
Re: Alternator swap
Postby donbenny1915 » October 23rd 2020, 1:45am
dchan51360 wrote:First of all, Welcome to the site.
DC
Is this the one that will fit the Astro?
donbenny1915
Years of Membership: donbenny1915 has been a member for 4 full yearsdonbenny1915 has been a member for 4 full yearsdonbenny1915 has been a member for 4 full yearsdonbenny1915 has been a member for 4 full years
Extra Info: Conversion awd
It is currently November 24th 2020, 8:17am
tungtide
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
Date: Nov 19 '20
Time: 7:31pm
