Temp, fuel, some lights working/not on dash
Postby Hiker2187 [OP] » October 21st 2020, 5:20pm
So I've been trying to troubleshoot this problem for days, I thought it was the alternator which did have blown diodes, changed that out. But the problem still resides. The temperature gauge, the fuel gauge don't work. The low fuel light is on ABS light is on. Battery is new alternators new charging at 13.4-13.6. Check the fuses pulled the dash and my wits end here. Figured I would ask some of you guys before I take it into an electrician. Couple of Old-Timers told me that at the ground mechanic friend told me that it's the dash.
Hiker2187
Van Model Year: 2001
Extra Info: 4.3
  • Blown #9 fuse, short, instruments, dash & rear lights out
    by HHAstro » December 3rd 2020, 6:23am in Electrical
    Last post by HHAstro View the latest post
    December 4th 2020, 12:33am
  • postition light not working properly
    by Danield » September 20th 2020, 8:59am in Electrical
    October 1st 2020, 6:45pm
    36
    March 4th 2021, 9:58am
Re: Temp, fuel, some lights working/not on dash
Postby TBLBill » October 22nd 2020, 5:59pm
I would check the wiring and plugs behind the gauge cluster, maybe something is loose. Then, look at the rest of the wiring going toward the temp sensor, fuel pump, and ABS module. The only thing that I don't see that often is the temp not working though - fuel gauge/low fuel light is a common problem, ABS light could be a speed sensor.
TBLBill
Years of Membership: TBLBill has been a member for 3 full yearsTBLBill has been a member for 3 full yearsTBLBill has been a member for 3 full years
Topics: 12
Images: 42
Extra Info: LS RWD
Postby Hiker2187 [OP] » October 22nd 2020, 6:19pm
I checked the cluster, pulled it and ran line down seens om. Could it be the cluster itself or multi func switch on the ignition?
Hiker2187
Extra Info: 4.3
Postby TBLBill » October 22nd 2020, 7:13pm
I'm not sure about the multi switch, but it could be the cluster. Can you get another one from a JY to test? Should be $10-20 to pull one.
TBLBill
Topics: 12
Images: 42
Extra Info: LS RWD
It is currently March 4th 2021, 9:58am
OldSchoolNoe
Comments: 0
Date: Mar 01 '21
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 22
Date: Feb 17 '21
Time: 4:26am
