HELP! TPS and MAP sensor connection mistake?!
Postby observer [OP] » November 19th 2020, 8:19am
I bought this 1989 van from someone, and today after checking the wiring/connectors on the van against a service manual, I suspect the previous owner swapped the TPS and MAP sensor connectors by mistake (because they look the same except for colors). If there was really an error, I am a bit surprised the van can and have been driven like that for quite a long time! :screaming:
Could someone please please check for me how yours are connected, and tell me which is the correct connector (shown in attached picture) for TPS?
On the black connector (this was connected to MAP):
A terminal: black wire
B: dark blue
C: grey
On the green connector (this was connected to TPS):
A terminal: black wire with red strip
B: green wire with black strip
C: grey
observer
Years of Membership: observer has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full yearsobserver has been a member for 12 full years
Topics: 13
  • Crankshaft position sensor
    by Devonian » November 12th 2020, 3:12pm in Electrical
    Last post by Devonian View the latest post
    November 14th 2020, 7:59pm
  • Crankshaft Position Sensor
    by Mberry0614 » January 10th 2021, 3:14am in Electrical
    January 11th 2021, 6:15am
    95
    January 17th 2021, 12:24am
Re: HELP! TPS and MAP sensor connection mistake?!
Postby AstroWill » November 20th 2020, 8:54pm
That is crazy, must have been in 'limp home' mode for a while.
observer wrote:On the black connector (this was connected to MAP):
B: dark blue
C: grey
Yep, that belongs on the TPS
observer wrote:On the green connector (this was connected to TPS):
C: grey
And that one belongs on the MAP sensor.
103254
Images: 460
Postby dcsleeper » November 20th 2020, 9:00pm
It runs, right? < sez the seller >
Profile | Edit signature
dcsleeper
Topics: 19
Images: 77
Alias (AKA): DC
It is currently January 17th 2021, 12:24am
OldSchoolNoe
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
doogaloo
Date: Dec 25 '20
Time: 10:06pm
Users browsing this forum: Google [Bot] and 11 guests
cron
