Voltage drop on the cluster gauge
Postby Olivier02 [OP] » November 26th 2020, 3:23am
Hi
I noticed a voltage drop when i put the front climate power at full blast and the rear defroster on (at idle ). When i accelerate it comes normal again. Does it have a link with my battery, alternator or wires ? Thanks a lot
Olivier02
Alias (AKA): Olivier
Extra Info: SLT AWD 4.3L
  • 1995 Astro Replaced Starter Now Running Low Voltage
    by Melvin-_-_-Marvelous » February 2nd 2021, 1:18pm in Electrical
    February 2nd 2021, 6:48pm
  • Drop in Alternator
    by Psyckosama » March 30th 2021, 6:22pm in Electrical
    Last post by Psyckosama View the latest post
    April 4th 2021, 5:03am
    9
    93
    April 13th 2021, 12:12pm
Re: Voltage drop on the cluster gauge
Postby Rod's Trucks » November 28th 2020, 1:19am
Quick answer: Yes, it is definitely linked! :banghead:
Explanation:
You are putting a large load on the electrical system, and the alternator is not supplying as much as needed to keep up when at Idle, so the system voltage drops some. You might even notice headlights get a bit dim under those conditions. On many systems. the charging voltage is 14 to 14.5 volts, but at idle that probably drops to close to the battery voltage when no charging ( 12-12.5 volts) . The dashboard 'voltmeter' is usually grossly inaccurate, for anything but general trends. I know mine reads nearly 2 volts high, if I go be the numbers on the gauge. Until I realized that, I was concerned about boiling my battery on long trips, but then I found the problem was only a high gauge reading.
That, roughly 2 volt difference, makes a noticeable difference in fan speeds and lamp brightness.
I would say to some extent, this is normal, but having an actual voltmeter connected to 'measure' the voltage present would give you better information.
Known problem areas are in the heater blower circuitry and particularly the dropping resistor assembly for the fan ( but that is bypassed in the HI position so it should not be part of your possible issue),
For short term situations, this condition should not be a problem, as the battery ( if it is a good one) has the capacity to fill in for the deficiency. Adding the WS wipers to the mix aggravates the situation a bit more.
Check all the electrical connections at the battery, and the grounds too. Also, you might want to look up the 'BIG 3" mod for wiring, That mod improves the main power circuitry to and from the alternator, battery and vehicle frame.
A voltmeter should measure close to the same voltage on the blower motor leads as it does at the battery, under the same conditions ( there will be slightly lower voltage at the blower motor due to normal losses in the wiring) I would suggest anything more than 1/2 volt might be cause for further investigation, but I have not actual experience with actual measurements on that circuit.
If you take some actual measurement s and have questions, come back with more details, and you will get more help.
Rod J
Issaquah, WA
Rod's Trucks
Topics: 35
Images: 57
Alias (AKA): Rod and/or WE7X
Postby Olivier02 [OP] » November 29th 2020, 3:14am
thanks a lot Rod ! i will look up for the big 3 mod. Do you know where i can buy it ?
Olivier02
Postby MmusicmanMmusicman is online! » November 29th 2020, 3:32am
Olivier02 wrote:When i accelerate it comes normal again.
This tells me your stock alternator isn't producing enough output at idle (when heavily loaded)
This is pretty much normal.
I had same problem running dual a/c on full, PLUS electric fan, plus headlights & auxiliary lights AT IDLE. Stock alternator was extremely inadequate. I installed a larger AD-244 case 145A alternator, which completely solved my troubles. I now have amazing output at idle. It dropped right in for me (but some have had to go one size larger belt).
See my story: https://www.astrosafari.com/viewtopic.php?f=76&t=143944
AD244 vs Stock
Topics: 73
Images: 59
Postby MechBob » November 29th 2020, 4:12am
Yes,no and maybe. Lots of misinformation,here.Automobiles are generally built to minimum standards.For the lights to get dim,heater to slow down,wipers to slow down,has been standard since the 1940's,when all vehicles had generators. Over the years,only higher priced vehicles,that came with alternators/batteries systems so this did not happen, did not have this problem.There is nothing wrong with your van,"as built". But you can upgrade it. And,I am sick and tired of people thinking this is an issue,usually comes from people that live in warm climates.How old are you people,13?
MechBob
Images: 12
Alias (AKA): Bob
Extra Info: 4x4
Postby Rod's Trucks » November 29th 2020, 7:57am
Olivier02
The Big 3 upgrade is not something you buy as a kit.
It is a process whereby you upgrade to some heavier wiring.
Go into the search box and put in big 3 upgrade; or go to the electrical section and look for it. It is one of the top three or four articles.
You buy the wire and the necessary terminals, and then you get to do the work to install it.
As others have indicated, what you are observing is pretty common. But as I said, a real voltmeter will give you enough information to figure out if is is cause for concern.
Rod J
Rod's Trucks
Topics: 35
Images: 57
It is currently April 13th 2021, 12:12pm
Attached by: GaryMacGuyver
GaryMacGuyver
Date: Apr 10 '21
Time: 11:29am
Comments: 36
Date: Apr 06 '21
Time: 11:08pm
Comments: 36
Date: Apr 06 '21
Time: 9:58pm
Ken2.7
Comments: 33
Date: Apr 04 '21
Time: 2:38am
LumaWJ
Date: Apr 01 '21
Time: 8:38am
Users browsing this forum: No registered users and 15 guests
