CEL not working correctly, Instrument panel?
Postby Themistocles [OP] » November 28th 2020, 5:40pm
My CEL has been acting screwy over the last few months. When I turn the key to “On” with engine off, the light will light up for the test along with the others, But then will stay on along with the battery indicator. Sometimes however, the light will not turn on at all. When I start the engine the light immediately turns off. This situation will continue with or without active error codes in the the system. If I get an error code the light WILL NOT turn on while the engine is running.
What gives? Is the instrument panel at fault? Is it the PCM? If I replace the panel, how would I test a junk yard panel without plugging it into my car first?
Themistocles
  • Temp, fuel, some lights working/not on dash
    by Hiker2187 » October 21st 2020, 5:20pm in Electrical
    October 22nd 2020, 7:13pm
  • low beams not working
    by david crockett » December 19th 2020, 9:18pm in Electrical
    December 22nd 2020, 12:14am
    7
    35
    April 21st 2021, 12:49am
Re: CEL not working correctly, Instrument panel?
Postby TBLBill » December 4th 2020, 1:25pm
I'm not sure of the cause, but I know some junkyards will let you bring in a good battery to hook up (if you can find a van with all the electronics still connected) to test it.
TBLBill
Years of Membership: TBLBill has been a member for 3 full yearsTBLBill has been a member for 3 full yearsTBLBill has been a member for 3 full years
Topics: 12
Images: 42
Extra Info: LS RWD
It is currently April 21st 2021, 12:49am
Attached by: GaryMacGuyver
GaryMacGuyver
Date: Apr 10 '21
Time: 11:29am
stentstent is online!
Comments: 36
Date: Apr 06 '21
Time: 11:08pm
Comments: 36
Date: Apr 06 '21
Time: 9:58pm
Ken2.7
Comments: 33
Date: Apr 04 '21
Time: 2:38am
Attached by: LumaWJ
LumaWJ
Date: Apr 01 '21
Time: 8:38am
