Diagnose With Me
Diagnose With Me
Postby OldSchoolNoe [OP] » January 16th 2021, 9:33pm
Hello all using a relay circuit tester to find a bad wire or bad ground. It is Cal-Van Tools 76. Simple tester the tool shows 2 lights, green = connected to battery and red = connection to ground. It tests battery to relay wiring (30) relay to switch (86) and relay to component (85)
Currently seeing what these lights tell me about the wires, what do you see? Van has crank no start condition. Fuel pump 60 psi, no blown fuses all relays passed a relay tester test.
Simple right? Here it is testing the fuel pump circuitry
Starter enable relay, looks normal to me
Tool has the ability to "turn on the component." This is how it looks when "cranking." This is on the starter enable relay, the starter itlsef works.
IGN relay, yeah something's not right here.
OldSchoolNoe
Alias (AKA): Noel
Extra Info: Explorer High-Top
Re: Diagnose With Me
Postby Rod's Trucks » January 16th 2021, 10:14pm
I am not familiar with that specific tool, but it appears to be able to test the circuit of a common Bosch style relay, and manually energize that relay circuit.
Wire #30 is power from fuse block, which will be switched to the load ( Pin #87), when the relay coil ( Pins #85 and #86) are energized.
If the circuit works as it should with the tool, and the relay tests OK, then the only logical result is that the control circuit for the relay is not present to operate the relay.
You will need to trace back up the control wiring to see where the necessary signal is ( should be) coming from.
Also, many of the relays are identical ( look closely at the markings and pin configuration to be sure) . You can easily swap identical relays to test for a possible bad one.
Rod J
Issaquah, WA
Rod's Trucks
Topics: 32
Images: 55
Alias (AKA): Rod and/or WE7X
Postby AstroWill » January 16th 2021, 10:58pm
Looks like a cool tool to have. I couldn't justify the price for me, I would just use a meter and some jumpers :)
Images: 472
Postby OldSchoolNoe [OP] » January 16th 2021, 11:17pm
OEM Tools and ATD Tools make the same tool, just a different brand gets stamped on it.
"There should be at least one red, and one green light illuminated, when testing any given circuit. Both the red and green light should not illuminate on any given circuit, as this indicates a short in the circuitry."
Oh so now those pictures are starting to make sense
Fuel Pump Relay - Both lights on for 30 and 86 = There's a short between the relay and the fuel pump switch (I'm assuming it would be ignition key)
Starter Enable Relay - Both lights on for 86 = There's a short between the relay and the starter switch (I'm assuming it would be the ignition key when turned)
IGN Relay - Both Lights on for 85 = There's a short between the relay and component. So what's IGN relay going to? The Ignition control module?
Not shown is the A/C Enable relay(5pin) . Tool says (red 30) (green and red 86) (green 85). There's a short on 86, relay to a/c switch?
Not shown is the A/C Relay (4pin) - (green red 30) (green 86) (green [dim red] 85). There's a short on 30 battery to relay.
I don't care for A/C so I can just leave those relays disconnected. I learned that the wiring to the starter switch is somewhat funky. Anyone agree with me? The ignition key is not the original, previous owner installed a different ignition lock cylinder. I do not know what the "IGN Relay" powers but I'm assuming it is the ICM.
OldSchoolNoe
Alias (AKA): Noel
Postby OldSchoolNoe [OP] » January 19th 2021, 2:19am
Used a test light on ignition switch connections and one of the pins gave a very weak light. I'm fairly certain the ignition switch is bad, before I buy a replacement I just want to make sure you guys agree.
Nice bright light on black cable indicating ground
Very weak connection on green cable
OldSchoolNoe
Alias (AKA): Noel
It is currently March 2nd 2021, 8:10pm
OldSchoolNoe
Comments: 0
Time: 12:53am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
