Composite to sealed beam DRL question
Postby AstroOafAdventurer [OP] » March 1st 2021, 4:31pm
So I'm gathering parts to swap my composite Astro to a Safari sealed beam grille.
Composite lights come on with the ignition, acting as DRL but I'm guessing it just triggers the low beam headlight circuit.
I'll be getting LED headlights, and looking at 2 models, one with a DRL halos, and the other no DRL.
I like the DRL, but it has a separate from the main connector wire for the DRL.
I'd like the DRL to come on with ignition, then when I turn the lights on, low beams activate and DRL goes off.
I want this to happen automatically, thinking it should be easily done with relays but I'd need a source from the light switch to trigger the relay.
Any thoughts on this or another way to wire them up to accomplish this?
97 Astrofari Conversion Van 62k 64k miles, 65k miles
AstroOafAdventurer
Topics: 43
Alias (AKA): Thorsteenster
Extra Info: RWD GMC grille
  • 2002 High beam what bulb?
    by smokinjoe » March 27th 2021, 6:56pm in Electrical
    April 1st 2021, 9:29pm
    7
    18
    April 20th 2021, 10:53pm
Re: Composite to sealed beam DRL question
Postby MI_Ghost » March 1st 2021, 11:19pm
The relay for the DRL/automatic lights is mounted on the driver B-pillar.
One of the tabs is for the DRL. Not sure which.
~Ghost
Ast' Cargo: 2001 Astro Cargo
Beauty: 2009 Impala LT
MI_Ghost
Topics: 7
Images: 107
Alias (AKA): Ghost
Van Model Year: 2001
Extra Info: Big White RWD Box
Postby AstroOafAdventurer [OP] » March 4th 2021, 7:59pm
Is that relay control just DRL, or low beams also? I don't have a diagram to check, but I wouldn't expect DRL to have a separate circuit when it's essentially just low beams on w/ignition.
AstroOafAdventurer
Topics: 43
Postby Leeann_93 » March 4th 2021, 11:57pm
Here are the '99 schematics. Dunno if they're the same for the '97.
Postby AstroOafAdventurer [OP] » March 5th 2021, 2:33am
Thanks Leeann!
So the wiring looks pretty much the same except the headlight connectors are wired for single/dual lights.
Maybe where my thinking is off, I'm of the understanding SB headlights are off with ignition on, no DRL, where as the composite headlights come on with the ignition, functioning as DRL. Looking at the diagrams above though, I'd say this isn't the case, I thought I'd seen somewhere here that SB's don't have DRL. In the second diagram though I am curious about the right hook off of LT GRN just before the headlights and what P100 and the E in the triangle mean...
AstroOafAdventurer
Topics: 43
Postby AstroOafAdventurer [OP] » March 5th 2021, 11:26pm
Eureka! I've had the diagram all along, well kinda. I linked it in another topic, but there is a relay as MI_Ghost said!
Looks like I'll need to disconnect the yellow wire from the relay or diode and run it to the DRL on the new lights.
Here's the diagram, both composite and SB models look to have the DRL relay
http://www.autolib.diakom.ru/CAR/Chevro ... S/9293.pdf
Also, 99 is different than the 97 fyi.
AstroOafAdventurer
Topics: 43
Postby MI_Ghost » March 7th 2021, 1:57pm
Yes, Sealed beam does have the DRL as well.
Now here is the bug. The DRL ties in with the automatic lights. If you seperate out the DRL to run halos or bars. You give up head lights in the automaic lights and will have only the running/parking lights. Which means you are back to manually turnning on the head lights. The automatic lights then become useless.
The trick will be to get the automatic lights to trigger a relay that will switch the DRL from the halos to low beam. And you can make mine p-n-p. :D
~Ghost
MI_Ghost
Topics: 7
Images: 107
Alias (AKA): Ghost
Postby AstroOafAdventurer [OP] » March 7th 2021, 3:24pm
Thanks, I thought I'd read somewhere here the sealed beams don't have DRL.
Looking the following diagram, I'm thinking I can take the yellow wire from the DRL diode to the DRL relay, and divert it from the relay to the halo for DRL.
I'll have to find an easy place to get to the yellow wire, I want to use a connector so I can easily switch back to stock if needed.
The DRL/halo will turn on with the ignition, and the headlight switch will turn the headlights on, DRL/halo off.
AstroOafAdventurer
Topics: 43
Postby AstroOafAdventurer [OP] » March 11th 2021, 6:01pm
Woop woop!!
AstroOafAdventurer
Topics: 43
It is currently April 20th 2021, 10:53pm
Attached by: GaryMacGuyver
GaryMacGuyver
Date: Apr 10 '21
Time: 11:29am
Comments: 36
Date: Apr 06 '21
Time: 11:08pm
Comments: 36
Date: Apr 06 '21
Time: 9:58pm
Ken2.7
Comments: 33
Date: Apr 04 '21
Time: 2:38am
Attached by: LumaWJ
LumaWJ
Date: Apr 01 '21
Time: 8:38am
