Trailer Wiring connection
Postby Up The Creek [OP] » March 29th 2012, 6:59am
Hello,
Does anyone know where I might find the connector for a 4 pin trailer wiring extension on a 1999 GMC safari. I don't see anything beneath the Jack on the passenger side.
Thanks
Martin
Up The Creek
Years of Membership: Up The Creek has been a member for 8 full yearsUp The Creek has been a member for 8 full yearsUp The Creek has been a member for 8 full yearsUp The Creek has been a member for 8 full yearsUp The Creek has been a member for 8 full yearsUp The Creek has been a member for 8 full yearsUp The Creek has been a member for 8 full yearsUp The Creek has been a member for 8 full years
Images: 2
Re: Trailer Wiring connection
Postby Big_kid » March 29th 2012, 1:30pm
I've read that it's either in the right rear pillar, or behind the right rear side panel. When I installed my trailer harness I didn't bother to look. Mines a conversion van and either one would have been more work to take off than to just make my own connections. I drilled a hole on either side, ran the wire up to the tail lights, soldered & shrink wrapped the connections, and put RTV around the wire to seal the hole where it passes through the floor. It's been 4 years so far, no troubles. I didn't need to add a brake controller until last year, but when I replaced the carpet I ran several wires for future use at that time. I connected one of those, and I was up and running (and stopping) in no time.
Welcome aboard!
:chevy:
Firing on 7 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
Postby RECox286 » March 29th 2012, 2:25pm
Your truck may not have had that RPO if you can't find it hovering in the jack area. I have only had 2 trucks out of the 5 or 6
I've had that came with the factory pigtail. So, I would say "you're on yer own" No problem, though, just remove the trim ** on
the driver side at the rear door, to gain access to the wiring harness that goes to the rear light fixtures. You will find everthing
you need to hook into on the truck side of the light fixture. For ease of installation, I get a terminal strip from Radio Shack
that accepts a small screw driver to tighten down on the cut and stripped wires.
Uncle Bob
** The rearmost utility pocket.
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
It is currently November 27th 2020, 6:27am
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
Date: Nov 19 '20
Time: 7:31pm
Users browsing this forum: No registered users and 15 guests
