no power to overhead switch panel 96 safari tiara
Postby coolerking [OP] » April 14th 2012, 4:06pm
Hi ,
recently a pal took off the overhead switch panel which operates the tv,reading lights and upper and lower mood lights. Unfortunately the brain dead idiot forgot to mark which wire went to which.[not colour coded].
Whilst trying to figure out which went where we had got all lights working and just on tv wiring when power to panel was lost. There is a seperate fuse board in rear for the panel, sofa bed, 12v supplies and a timer for the instrument panel so it can be used without ignition but only for minutes set on timer.
Cant find any fuses gone here or under steering column or under bonnet. put meter on and cant get power into the timer unit so assume there must be an inline fuse somewhere. Absolutely stumped - any ideas ?
coolerking
Years of Membership: coolerking has been a member for 9 full yearscoolerking has been a member for 9 full yearscoolerking has been a member for 9 full yearscoolerking has been a member for 9 full yearscoolerking has been a member for 9 full yearscoolerking has been a member for 9 full yearscoolerking has been a member for 9 full yearscoolerking has been a member for 9 full yearscoolerking has been a member for 9 full years
Van Model Year: 1996
Extra Info: awd
  • No power
    by equitube » September 13th 2020, 4:55am in Electrical
    September 17th 2020, 5:40am
  • Van dies; NO power anywhere, but batt will show full Volts
    by SoFar,EH » January 12th 2021, 2:10am in Electrical
    January 15th 2021, 5:35am
    80
    February 28th 2021, 7:24am
Re: no power to overhead switch panel 96 safari tiara
Postby Jasen » April 16th 2012, 5:14pm
The only one that's going to have a wiring schematic for that stuff is going to be the Mfg. if there sill in business, they might be able to help you out. If not your stuck tracing everything out.
I'm a Journeyman woodworker,
Every projects a journey man.
200k
Ultra gauge
Topics: 260
Images: 101
It is currently February 28th 2021, 7:24am
tungtide
Date: Feb 23 '21
Time: 1:54am
Rockridge
Date: Feb 20 '21
Time: 1:28am
Coronavan
Date: Feb 17 '21
Time: 7:21pm
Attached by: Primusblack
Primusblack
Comments: 21
Date: Feb 17 '21
Time: 4:26am
OldSchoolNoe
Comments: 9
Date: Feb 13 '21
Time: 11:56pm
