white connection...
white connection...
Postby ltomasj [OP] » May 2nd 2012, 8:15am
in astro-95 there is a white connection behinde the compuer on the passanger side,its 10 sall pin in this, but only 9 vires, can someone explain what the wires go to....
ltomasj
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: ltomasj has been a member for 8 full yearsltomasj has been a member for 8 full yearsltomasj has been a member for 8 full yearsltomasj has been a member for 8 full yearsltomasj has been a member for 8 full yearsltomasj has been a member for 8 full yearsltomasj has been a member for 8 full yearsltomasj has been a member for 8 full years
Topics: 27
Images: 16
Alias (AKA): tomas
Extra Info: 4.3l
  • HELP! TPS and MAP sensor connection mistake?!
    by observer » November 19th 2020, 8:19am in Electrical
    Last post by dcsleeperdcsleeper is online! View the latest post
    November 20th 2020, 9:00pm
    48
    November 25th 2020, 3:06am
Re: white connection...pictures
Postby ltomasj [OP] » May 2nd 2012, 3:48pm
here is the pictures of the cabels..
ltomasj
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 27
Images: 16
Alias (AKA): tomas
Extra Info: 4.3l
Postby Lumpy » May 2nd 2012, 9:37pm
Speakers is my first guess. If you had a factory service manual for your year van, about 20-30 bucks on eBay, you could tell exactly. As long as the thing is OEM.
I dig just looking through my FSM. Drawings, photographs, text descriptions, wire colors, dexcriptions of what tools to use. Esp for electrical stuff, the FSM is a great resource. Typically in two parts. One for mechanical and a supplemental part for electrical. Get both. Mine was $19.
Postby ltomasj [OP] » May 3rd 2012, 6:13am
thanks, if its the speakers i have lost expensive time to wondering of that, but thats life!
thank you "lump"..
ltomasj
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 27
Images: 16
Alias (AKA): tomas
Extra Info: 4.3l
Postby ltomasj [OP] » May 4th 2012, 5:30am
the cabels going to something that called IAC, a little plastic box under the dashbord, and out to the engine connected to TPS and IAC , so its not the radio or speakers...is IAC something i need ????
ltomasj
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 27
Images: 16
Alias (AKA): tomas
Extra Info: 4.3l
Postby DGE73 » May 19th 2012, 3:29am
I think you are looking at the Cruise Control Module's wiring harness connector.
Your van probably didn't come with cruise, but all the cruise control wiring is included in your van's basic factory wiring.
03 Astro RWD 220k Write off
96 Safari RWD sold @ 210k, retired as Florida RV
94 Safari swb RWD scrap @ 240k
DGE73
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: DGE73 has been a member for 8 full yearsDGE73 has been a member for 8 full yearsDGE73 has been a member for 8 full yearsDGE73 has been a member for 8 full yearsDGE73 has been a member for 8 full yearsDGE73 has been a member for 8 full yearsDGE73 has been a member for 8 full yearsDGE73 has been a member for 8 full years
Extra Info: RWD with Tow Package
Postby Phantom » May 19th 2012, 3:12pm
ltomasj wrote:the cabels going to something that called IAC, a little plastic box under the dashbord, and out to the engine connected to TPS and IAC , so its not the radio or speakers...is IAC something i need ????
IAC = Idle Air Control
TPS = Throttle Position Sensor
Phantom
Firing on 7 Cylinders (L4)
It is currently November 25th 2020, 3:06am
tungtide
Date: Nov 23 '20
Time: 4:40pm
Comments: 24
Date: Nov 20 '20
Time: 8:18am
Date: Nov 20 '20
Time: 1:16am
Date: Nov 19 '20
Time: 8:00pm
Date: Nov 19 '20
Time: 7:31pm
