Rear A/C Switch Burned Up
Postby kramerhd [OP] » June 11th 2012, 2:13am
well today it finally happened. I've seen it before, but it finally happened to mine.
the switch got jammed slightly and then i smelled the burning smell.
So what is the root cause for this,(Beside the switch jamming.)
I've had to replace the relay a few times due to it get burned up. I've even reduced the fuse by 10amp.
I'm going to the local salvage yard to get a replacement harness and switch this week.
But what Is causing it to happen in the first place????
1999 GMC Safari AWD(138,000miles)
Rear A/C switch
kramerhd
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: kramerhd has been a member for 8 full yearskramerhd has been a member for 8 full yearskramerhd has been a member for 8 full yearskramerhd has been a member for 8 full yearskramerhd has been a member for 8 full yearskramerhd has been a member for 8 full yearskramerhd has been a member for 8 full yearskramerhd has been a member for 8 full years
Topics: 7
Images: 10
Alias (AKA): Kramerhd
Extra Info: SLT AWD
  • Rear wiper switch button
    by Olivier02 » October 11th 2020, 8:34pm in Electrical
    October 27th 2020, 6:45pm
  • Door window switch electrical connector
    by AstroOafAdventurer » August 26th 2020, 10:28pm in Electrical
    Last post by AstroOafAdventurer View the latest post
    August 27th 2020, 8:47pm
    January 26th 2021, 12:08pm
Re: Rear A/C Switch Burned Up
Postby tomasw » June 15th 2012, 7:58am
The problem is GM's scare of contact relays. If you lead 10 amp or more thru a tiny copper plate inbedded i plastic, you have got this problem if a minor rise in amps happens(or lack of voltage. 120watts /12v = 10amps but 120 watt / 10v = 12amp )
Then fry!!
And as allways, dont mind my english, im a swed
Hope nobody saw me killed ohms law erlier :)
1995 chevy astro LT AWD
1995 chevy astro AWD for spareparts
Oldsmobile Cutlass 1976, 455, T-top
Opel Omega 2.5, 1998 (Caddy Catera)
SAAB 9-5, 2.0t 2000
tomasw
Years of Membership: tomasw has been a member for 8 full yearstomasw has been a member for 8 full yearstomasw has been a member for 8 full yearstomasw has been a member for 8 full yearstomasw has been a member for 8 full yearstomasw has been a member for 8 full yearstomasw has been a member for 8 full yearstomasw has been a member for 8 full years
Extra Info: 4.3 LT AWD
Postby kramerhd [OP] » June 16th 2012, 3:18pm
So what can be done to correct this amp issue.?
kramerhd
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 7
Images: 10
Extra Info: SLT AWD
Postby tomasw » June 16th 2012, 7:35pm
put a standard 12v car relay Image
It should be wired up with direkt battery voltage thru the contacts 30 and 87 and on off-regulations in coil-connections (85, 86)
I stole this from a site, it explain the baics, the blue whire in the pic is the on thats goes from the switch (and only gets some 80mA)
how you should do the couplings in you car, it's up to you. I think that the most importent is to relay hi-speed on rear AC/heater (steals 13 amp I beleve). On ordinary heater/AC hi-speed all ready got a realy
I'm fighting with my own 1995 that have no volt at allto the rears.. I'm shure it will end up with a few relay and special connections when I'm ready....
SAAB 9-5, 2.0t 2000
tomasw
Postby kramerhd [OP] » October 13th 2012, 2:08pm
THE DAMN THING DID IT AGAIN!!!
(New switch and a new harness) :banghead:
Can someone show me what the (+) Neutral and Ground Wire is.
I would like to just wire in a Regular toggle switch.
kramerhd
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 7
Images: 10
Extra Info: SLT AWD
Postby Lumpy » October 13th 2012, 2:49pm
Just curious, Kramer...
Why do you post in that giant purple font?
Postby kramerhd [OP] » October 13th 2012, 3:51pm
Lumpy wrote:Just curious, Kramer...
For ****'z-n-Giggle :confused:
kramerhd
Fueling (1/2 tank)
Fueling (1/2 tank)
Topics: 7
Images: 10
Extra Info: SLT AWD
It is currently January 26th 2021, 12:08pm
OldSchoolNoe
Date: Jan 19 '21
Time: 2:15am
OldSchoolNoe
Date: Jan 16 '21
Time: 9:23pm
Comments: 9
Date: Jan 15 '21
Time: 5:08am
Attached by: markmitch
Date: Jan 04 '21
Time: 6:15pm
doogaloo
Date: Jan 04 '21
Time: 11:53am
