ODB Not Working
ODB Not Working
Postby beauxolo [OP] » July 10th 2012, 2:43am
I plugged in an Ultra Gauge and there no response from the device. It works on my Subaru. Any ideas on what I could check?
beauxolo
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: beauxolo has been a member for 8 full yearsbeauxolo has been a member for 8 full yearsbeauxolo has been a member for 8 full yearsbeauxolo has been a member for 8 full yearsbeauxolo has been a member for 8 full yearsbeauxolo has been a member for 8 full yearsbeauxolo has been a member for 8 full yearsbeauxolo has been a member for 8 full years
Van Model Year: 2002
  • Cluster: All warning lights on and most gauges not working
    by akev527 » May 5th 2020, 7:18am in Electrical
    Last post by akev527 View the latest post
    May 7th 2020, 12:13am
  • wipers not always working
    by daj120388 » July 8th 2020, 11:14pm in Electrical
    July 8th 2020, 11:49pm
    55
    October 22nd 2020, 7:26am
Re: ODB Not Working
Postby Phantom » July 10th 2012, 3:35am
beauxolo wrote:I plugged in an Ultra Gauge and there no response from the device. It works on my Subaru. Any ideas on what I could check?
Compare the protocols that it uses and see if it matches what GM in your year used , sometimes the gauge/scanners use different protocols
also make sure the fuse for the OBD port is good , it usually the same as the extra power outlets in the side of the glove box
Go to autozone and see if theirs works , if it does then it is the scanner/gauge you have
Phantom
Firing on 7 Cylinders (L4)
ODB Not Working
Postby beauxolo [OP] » July 10th 2012, 5:34am
Might be that fuse - I noticed the power/lighter outlet on the side didn't work. Checking it out tomorrow.
beauxolo
Fueling (1/2 tank)
Fueling (1/2 tank)
Re: ODB Not Working
Postby beauxolo [OP] » July 10th 2012, 6:19am
I see the fuse box under the dash, but Isn't there also a fuse box in the engine compartment - where is it located?
beauxolo
Fueling (1/2 tank)
Fueling (1/2 tank)
Re: ODB Not Working
Postby Phantom » July 10th 2012, 6:29am
beauxolo wrote:I see the fuse box under the dash, but Isn't there also a fuse box in the engine compartment - where is it located?
under the dash
Phantom
Re: ODB Not Working
Postby Phantom » July 10th 2012, 6:32am
Fuse 7
the BATT fuse under the hood also , but if your radio cig lighter , hazard lights are working then that fuse is likely good
Phantom
Re: ODB Not Working
Postby beauxolo [OP] » July 10th 2012, 7:15pm
Problem solved - it was a fuse. Thanks for the tip!
beauxolo
Fueling (1/2 tank)
Fueling (1/2 tank)
It is currently October 22nd 2020, 7:26am
nwisehart
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Date: Oct 10 '20
Time: 4:52pm
Maddog
Date: Oct 09 '20
Time: 4:08pm
Users browsing this forum: No registered users and 15 guests
