Starter don´t work.......
Postby Astro-van.de [OP] » October 19th 2008, 6:41pm
Hi ,
i have a massive Problem : My Starter didn´t work.
Even the Startersoleniod didn´t "klick".
I changed die Ignitionswitch, Startersolenoid, i used a 16mm²-Cable from the Solenoidterminal direct to the Battery - NOTHING :screaming: :screaming: :screaming: :screaming: :screaming: :screaming:
Has anyone here an Idea what is wrong with my Astro :?: :?: :?: :?: :?:
The faszinating on this Error is, sometimes ( on his goodwill) he works, but not often.
My Astro stand sill sice 1 1/2 Week, thats beats me.
kind regards Jens
Bj.90, 2WD, Motorcode : Z, short, Cargo, highjacked,LPG (LR LCS1 110l-Stako) 1GCCM15Z6LB......
now i have an new Bumper in the Back 8-)
Astro-van.de
Years of Membership: Astro-van.de has been a member for 12 full yearsAstro-van.de has been a member for 12 full yearsAstro-van.de has been a member for 12 full yearsAstro-van.de has been a member for 12 full yearsAstro-van.de has been a member for 12 full yearsAstro-van.de has been a member for 12 full yearsAstro-van.de has been a member for 12 full yearsAstro-van.de has been a member for 12 full yearsAstro-van.de has been a member for 12 full yearsAstro-van.de has been a member for 12 full yearsAstro-van.de has been a member for 12 full yearsAstro-van.de has been a member for 12 full years
Re: Starter don´t work.......
Postby Big_kid » October 20th 2008, 1:37am
Clean battery terminals?
Good ground?
Engine ground strap? (you can test using jumper cables for a ground)
Neutral safety switch?(will it start in Neutral?)
Dead cell in battery?
Bad starter motor?
Tap starter with a hammer, will it start then? :?:
Sounds like a bad connection or a bad starter motor.
Let us know what you find!
Firing on 6 Cylinders (L7)
Topics: 185
Images: 333
Extra Info: 2WD 5.7 V8
Postby Astro-van.de [OP] » October 20th 2008, 7:00am
Hi,
1. yes, cleaned and greased.
2. Ground is 1,1 Ohm (i think is goog ground)
3. This is a good Idea, it will be tested. :)
4. Switch is switching, i tested it .
5. The Battery is a 3 Year old Optima Yellow Top, i will test it ( at the Garage)
6. The Startermotor turns good, i tested him with jump cables in front of the Astro with the Optima Battery.
7. Sorry, no, because i hear noc klick from the Solenoid.
If i find the Error in the System , i will report it.
Thx.
kind regards Jens
Astro-van.de
Postby Astro-van.de [OP] » October 29th 2008, 3:40pm
Hi,
i changed the both Cords from the Battery to the Engine an to the Starter, but.......nothing.
At least i bought a new Starter and it will work.
I don´t know why the other Starter don´t work installed. It works with jumpercables in front of my Astro.
year, i can drive again (afer 2 weeks of standing still)
:banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana: :banana:
regards Jens
Astro-van.de
Postby Big_kid » October 30th 2008, 1:39am
Could be a dead spot in the starter motor. If that's the case, replacement is the only repair.
Glad you're running again!
Topics: 185
Images: 333
It is currently October 21st 2020, 3:35am
nwisehart
Date: Today
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Date: Oct 10 '20
Time: 4:52pm
Maddog
Date: Oct 09 '20
Time: 4:08pm
