Odd power lock question
Postby thestrange [OP] » October 7th 2012, 12:40am
Hey there first, I am new to the forum, and the van lifestyle but love it. Second, I picked up a 94 astro EXT and the power lock on the passenger door work and control the slider door lock as well. HOWEVER the drivers power lock will not from either door. I tested the switch and it is getting power and directs it accordingly when lock/unlock is pressed. I ran a jumper to the actuator in the door and it worked great. I tested the wire at the actuator and it is NOT getting power at all. I located the fuse and relays and their good. but I am unsure if the relay is a 2 in 1 kind of relay? Any ideas? also if i could get a wire diagram for the power locks that would be great.
thestrange
Years of Membership: thestrange has been a member for 7 full yearsthestrange has been a member for 7 full yearsthestrange has been a member for 7 full yearsthestrange has been a member for 7 full yearsthestrange has been a member for 7 full yearsthestrange has been a member for 7 full yearsthestrange has been a member for 7 full years
Alias (AKA): joe
Extra Info: EXT
  • Power windows and power acc circuit breaker
    by GSouthee » March 25th 2020, 6:58pm in Electrical
    March 30th 2020, 6:27pm
  • Dutch door glass hatch lock
    by ElroyJetson » February 23rd 2020, 1:09am in Electrical
    February 23rd 2020, 3:44pm
    August 12th 2020, 7:42am
Re: Odd power lock question
Postby thestrange [OP] » October 7th 2012, 2:08am
Does anyone know if I can see the power lock wires if I remove the engine cover? I don't want to go through the process if I don't have to.
thestrange
Alias (AKA): joe
Extra Info: EXT
Postby RECox286 » October 7th 2012, 4:09am
One possibility: The wiring passes from the door to the body thru a flexible boot in the middle of the door. One problem
that seems to crop up is that when the door is opened and closed, the wires flex and move around. I have had to splice
broken wires for just this reason. So, you may want to explore the possibility that you have a broken wire(s).
Good hunting
Uncle Bob
RECox286
Purple Status (L6)
Purple Status (L6)
Topics: 40
Alias (AKA): Uncle Bob
Extra Info: RWD V6 [325K mi]
Postby thestrange [OP] » October 8th 2012, 3:35am
Thanks, uh Uncle Bob.lol. I'll check that out soon.
Id still like to know if i can see the power lock wires if i were to remove the in cab engine cover?
thestrange
Alias (AKA): joe
Extra Info: EXT
It is currently August 12th 2020, 7:42am
Sailing_Faith
Comments: 17
Date: Aug 10 '20
Time: 2:17am
doogaloo
Comments: 17
Date: Aug 09 '20
Time: 8:52pm
Attached by: kittenflaps
kittenflaps
Comments: 18
Date: Aug 07 '20
Time: 12:46am
Sailing_Faith
Comments: 17
Date: Aug 06 '20
Time: 4:48pm
Attached by: bowtie262
bowtie262
Date: Aug 02 '20
Time: 8:41pm
