Starter, Alternator or Ignition?? Please help
Postby marco10 [OP] » November 14th 2012, 2:37pm
About a month ago I started having problems with starting my 2003 Chevy Astro. When I turn the ignition, it would not start. Battery is only 8 months old. The head lights are bright and all dash lights are lit. No sound like clicking or anything when I turn the key .... but if I turn the key very, very, very slowly, it starts normally. This happens usually in the mornings but not every morning. After that it will start normally the rest of the day. Now that the weather is getting a little colder, it is happening more often. I have checked and cleaned the battery terminals and there is good electrical contact. Not sure what else to check.
marco10
Years of Membership: marco10 has been a member for 12 full yearsmarco10 has been a member for 12 full yearsmarco10 has been a member for 12 full yearsmarco10 has been a member for 12 full yearsmarco10 has been a member for 12 full yearsmarco10 has been a member for 12 full yearsmarco10 has been a member for 12 full yearsmarco10 has been a member for 12 full yearsmarco10 has been a member for 12 full yearsmarco10 has been a member for 12 full yearsmarco10 has been a member for 12 full yearsmarco10 has been a member for 12 full years
  • Question about the starter
    by bradaskins » June 1st 2020, 7:43pm in Electrical
    Last post by Astrofarian View the latest post
    June 2nd 2020, 2:00pm
  • Good High End Alternator?
    July 4th 2020, 2:16am
    9
    36
    September 19th 2020, 1:35pm
Re: Starter, Alternator or Ignition?? Please help
Postby Ragenme » November 14th 2012, 4:02pm
Sounds like the ignition. I would take the cover off and look at the connetions.
ragenme If you can't fix it with a hammer then its probably a electrical problem!
Ragenme
Years of Membership: Ragenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full yearsRagenme has been a member for 8 full years
Topics: 16
Images: 23
Alias (AKA): Ragenme
Extra Info: SLX 4.3 V6 RWD
Postby Astronomical1987 » November 14th 2012, 4:16pm
The igition is an all or nothing deal so whether you turn it slowly or quickly it should have the same end result. Given the fact that you can alter its behaivor based on the speed of turning the key seems to indicate it is definately a problem with the ignition switch.
2003 Chevy Astro LT
1990 Olds Cutlass Supreme International Coupe
2006 Caddy CTS Sport
Astronomical1987
Fueling (1/2 tank)
Fueling (1/2 tank)
Years of Membership: Astronomical1987 has been a member for 7 full yearsAstronomical1987 has been a member for 7 full yearsAstronomical1987 has been a member for 7 full yearsAstronomical1987 has been a member for 7 full yearsAstronomical1987 has been a member for 7 full yearsAstronomical1987 has been a member for 7 full yearsAstronomical1987 has been a member for 7 full years
Alias (AKA): 96SafariAWD
Extra Info: LT 4.3L 82k
Postby Spider'sSafari » November 14th 2012, 4:26pm
The starter actucator switch is located at the bottom of the steering column, it's sounds like that's where the problem is IF you are not getting any Click from the starter Solenoid when you turn the key.
From the key switch to the actucator, there is a rod inside the column, when the key is turned it pushes that rod completing the electrical patch to the starter. That is a slight slider adjustment on the actucator that can be done to see if that's your problem.
It's at the base of the steering column on top so you do have to drop the column and remove the covers to get to it.
Start there, look under dash you may even be able to get to it to make the adjustment without the column drop.
Most common wear is using the wheel tilt too much, which will develop play in the whole column and not let the rod ingauge all the way.
Spider'sSafari
Years of Membership: Spider'sSafari has been a member for 7 full yearsSpider'sSafari has been a member for 7 full yearsSpider'sSafari has been a member for 7 full yearsSpider'sSafari has been a member for 7 full yearsSpider'sSafari has been a member for 7 full yearsSpider'sSafari has been a member for 7 full yearsSpider'sSafari has been a member for 7 full years
Images: 24
Alias (AKA): Spider
Extra Info: Mark III Denali Conv
It is currently September 19th 2020, 1:35pm
Gabor Latte
Comments: 13
Time: 9:37pm
Date: Sep 16 '20
Time: 1:08am
Attached by: WinnieVan
WinnieVan
Date: Aug 28 '20
Time: 10:45pm
Date: Aug 27 '20
Time: 9:51pm
thenextdon13
Date: Aug 28 '20
Time: 3:09am
