security bypass for remote starter
Postby berd [OP] » December 4th 2008, 5:25am
Just wondering if anyone knows how to bypass or disable the stock security feature on my 99 safari. Without a key turned in the ignition the fuel pump will not operate so somehow this needs to be bypassed or disabled in order to install a remote starter. I'm comfortable with all the rest of the wiring but this is the one I'm stuck on....any info would be much appreciated.
thanks in advance
:D
berd
Years of Membership: berd has been a member for 12 full yearsberd has been a member for 12 full yearsberd has been a member for 12 full yearsberd has been a member for 12 full yearsberd has been a member for 12 full yearsberd has been a member for 12 full yearsberd has been a member for 12 full yearsberd has been a member for 12 full yearsberd has been a member for 12 full yearsberd has been a member for 12 full yearsberd has been a member for 12 full yearsberd has been a member for 12 full years
Re: security bypass for remote starter
Postby spongebob218 » December 4th 2008, 11:27am
There are bypass modules available for the antitheft system. They are usually pretty cheap and a easy to install. Try to find one that auto learns the resistance for the passlock system, otherwise you will need to measure the resistance and dial it in to the unit.
I have installed a few remote starters and this module is the easiest to use. If I remember correctly, it hooks up to battery+, the ignition three output(should be a switched ground for controlling a relay), and the passlock wires from the ignition switch. The instructions are pretty simple.
http://www.amazon.com/JBS-Technologies-791-Universal-Learning/dp/B0003NF60I/ref=pd_sim_auto_7
You ain't nothin' unless you have green plugs.
spongebob218
Years of Membership: spongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full yearsspongebob218 has been a member for 12 full years
Postby webcat » December 5th 2008, 8:22am
another option for bypassing passlock II
in the picture below are all the possible resistance values your van could have ( GM uses 15 different resistance values)
when you measure the resistance in the circuit by your ( key cylinder lock ) it will be one of these values that you will need.
your job is to find out which one your van has . piece of cake
webcat
Firing on 3 Cylinders (L3)
Topics: 253
Alias (AKA): Larry aka Rambo
Extra Info: g10 5.7L vortec
Postby webcat » December 5th 2008, 11:05am
heres a link that will show you in great detail the relay method and how to find which resister you need
http://www.jaycorptech.com/tech/passlock.htm
xtra info
heres a link with info to wire just about anything on your van
http://www.the12volt.com/ohm/basics.asp
wiring keyless entry
power door lock-------light blue wire
power door unlock -----white wire
webcat
Topics: 253
It is currently October 21st 2020, 2:50am
nwisehart
Date: Today
Time: 12:44am
Olivier02
Date: Oct 11 '20
Time: 8:34pm
Date: Oct 10 '20
Time: 5:08pm
Date: Oct 10 '20
Time: 4:52pm
Maddog
Date: Oct 09 '20
Time: 4:08pm
cron
