Daytime Running Lights
Postby Bearsdad [OP] » January 3rd 2009, 4:25am
I just noticed that my Daytime Running Lights are not coming on when the Van (95 AWD Safari Canadian Model) is running. Is there a fuse that controls them or is there a module and or switch that needs to be checked out. I have looked in the Owners Manual and there is not a fuse that is mentioned. Any help is greatly appreciated. :flags-canada:
Bearsdad
Years of Membership: Bearsdad has been a member for 12 full yearsBearsdad has been a member for 12 full yearsBearsdad has been a member for 12 full yearsBearsdad has been a member for 12 full yearsBearsdad has been a member for 12 full yearsBearsdad has been a member for 12 full yearsBearsdad has been a member for 12 full yearsBearsdad has been a member for 12 full yearsBearsdad has been a member for 12 full yearsBearsdad has been a member for 12 full yearsBearsdad has been a member for 12 full yearsBearsdad has been a member for 12 full years
  • Turning off Daytime Running Lights
    by Mr.P » August 2nd 2020, 6:13pm in Electrical
    Last post by Mr.P View the latest post
    August 7th 2020, 5:30am
  • Day time running light indicator suddenly on
    by JodiSouza » July 7th 2020, 11:31am in Electrical
    Last post by JodiSouza View the latest post
    July 9th 2020, 2:12pm
    9
    82
    September 19th 2020, 1:33pm
Re: Daytime Running Lights
Postby DRZ » January 3rd 2009, 5:31am
Is the parking brake totally off?? There is a ground wire at the base of the parking brake assy. When the park brake is on, the wire grounds and the driving lights go off, you could just unplug it and see what happens I guess.
DRZ
Firing on 5 Cylinders (L2)
Years of Membership: DRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full yearsDRZ has been a member for 12 full years
Topics: 53
Images: 55
Alias (AKA): HPbyStan
Extra Info: awd cargo Alloys
Postby lmo » January 18th 2009, 4:51am
Stupid question, but do you high beams work?
Otherwise, if you turn the headlights on then off, does it wake them up? If so, clean the headlight plug connections.
My '95 Suburban currently has the first problem (I'll fix it tomorow, thanks to a forcasted 5 degrees C) and my '93 Astro has had the second problem.
Good Luck!
lmo
Years of Membership: lmo has been a member for 11 full yearslmo has been a member for 11 full yearslmo has been a member for 11 full yearslmo has been a member for 11 full yearslmo has been a member for 11 full yearslmo has been a member for 11 full yearslmo has been a member for 11 full yearslmo has been a member for 11 full yearslmo has been a member for 11 full yearslmo has been a member for 11 full yearslmo has been a member for 11 full years
Postby Matrixx » January 18th 2009, 1:53pm
Hi Bearsdad
I would check the parking brake first. Just pull up on it when it has been released and see what happens. Theirs a small plastic switch hooked up the the parking brake frame work that operates the DRLs at that point you can check as well. With my year (and should be with yours) their is a fuse marked DRL at the fuse box located inside, under the dash, just left of the brake pedal up on the firewall. You might want to check that as well to make sure it's not blown. Hope something here helps. Please keep us updated,Thanks.:)
Matrixx
It is currently September 19th 2020, 1:33pm
Gabor Latte
Comments: 13
Time: 9:37pm
Date: Sep 16 '20
Time: 1:08am
Attached by: WinnieVan
WinnieVan
Date: Aug 28 '20
Time: 10:45pm
Date: Aug 27 '20
Time: 9:51pm
thenextdon13
Date: Aug 28 '20
Time: 3:09am
