Hello all,
I'm having an issue with my headlights on my Canadian base model Astro. The daytime running lights are currently running on the low beams when I believe they are supposed to be on the high beam side. The headlights themselves are not working. The park brake switch does what it is supposed to and the low beam bulbs were very recently replaced and are working. The high beam bulbs were working a couple of days ago. As far the as the headlight switch goes it turns on the tail and front marker lights as it should and also turns off the DRLs as it should. Are there any other parts I should be looking at? Any suggestions?
Thanks in advance
Ian
97 Astro base model
