headlights go on and off
Postby drw1267 [OP] » February 17th 2009, 1:29pm
while driving headlights will go out, neither high beam or low will work. But all other lights still work, then few minutes later the lights come back on. Is there a relay just for the headlights? If so how do you check it?
2000 Astro V6 AWD 155000 miles A/C
drw1267
Years of Membership: drw1267 has been a member for 12 full yearsdrw1267 has been a member for 12 full yearsdrw1267 has been a member for 12 full yearsdrw1267 has been a member for 12 full yearsdrw1267 has been a member for 12 full yearsdrw1267 has been a member for 12 full yearsdrw1267 has been a member for 12 full yearsdrw1267 has been a member for 12 full yearsdrw1267 has been a member for 12 full yearsdrw1267 has been a member for 12 full yearsdrw1267 has been a member for 12 full yearsdrw1267 has been a member for 12 full years
  • daytime running headlights and dash out at same time help!
    by Nomad » January 4th 2021, 10:26pm in Electrical
    Last post by Nomad View the latest post
  • What does this plug go to?
    by Chrisaeff » May 2nd 2021, 12:18am in Electrical
    May 21st 2021, 3:35am
    7
    43
    June 25th 2021, 11:41am
Re: headlights go on and off
Postby Matrixx » February 17th 2009, 3:41pm
Hi drw1267
Welcome to the Forum
It's hard to answer questions without the details given. I have posted a link for you to click on that will help you with this, thanks.:)
viewtopic.php?f=4&t=2171
Matrixx
Postby Matrixx » February 17th 2009, 5:57pm
Hi drw1267
Their is a head lamp relay in the "Underhood Fuse Block" in the engine compartment. You can check that and if you have any more questions just ask. Thanks.:)
Matrixx
Postby drw1267 [OP] » February 17th 2009, 7:38pm
Hi Matrixx,
How can you tell if they're bad? or going bad?
drw1267
Postby Matrixx » February 18th 2009, 7:28pm
Hi drw1267
You really can't properly with relays with an intermittent like you have. I just find another relay with the same part number and swap it over to check. I find that to be least time consuming for that particular area (relays).
This could also be the headlight switch as well so don't rule that out until it's checked with the others. Do you have the "Ambient Light Sensor" with your vehicle? The easiest way to find this out, is just look at the switch itself. If it says "Auto-Park-Lights" then the sensor will be located in the center defrost grille on the dash. Hope this helps. Please keep us updated, thanks.:)
Matrixx
Postby astro355 » February 18th 2009, 7:35pm
I had this exact problem in my firebird. It turned out to be that the hot wire for the switch had rubbed against a piece of metal in the dash and grounded. No rhyme or reason as to when it would ground and not.
Have you done any work to the van at all before the problem started?
astro355
Firing on 4 Cylinders (L6)
Years of Membership: astro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full yearsastro355 has been a member for 13 full years
Extra Info: 355 V8 700R4
Postby drw1267 [OP] » February 18th 2009, 9:33pm
HI Matrixx,
Yes I have the ambient light sensor in the grill. Also the only work I had done was the front bumper was repainted.
drw1267
Postby marcus38 » February 18th 2009, 11:03pm
check the plug connector where it attaches to the bulb. i had one do that to me on my 90. cleaned the terminals added dielectric grease and it was cured. i know both of yours are doin it but still give that a look.
1990 astro CS 4.3 z engine 700r trans 2WD radical custom build
marcus38
Years of Membership: marcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full yearsmarcus38 has been a member for 12 full years
Topics: 35
Images: 5
Alias (AKA): mark
It is currently June 25th 2021, 11:41am
Comments: 64
Date: Jun 23 '21
Time: 6:52am
Ken2.7
Comments: 39
Date: Jun 18 '21
Time: 10:16pm
SoccerMom4x4
Date: Jun 17 '21
Time: 1:30am
joeg
Date: Jun 16 '21
Time: 11:56pm
Date: Jun 16 '21
Time: 10:47pm
